Hot outside f150 misses
on
What throttle positions does it do it in? Also, all gears? Misfire problems associated with bad COPs or fouled plugs usually show up around medium load on the engine and are more likely when its warmer. If you have a tuner keep it connected and datalog any misfires to determine if its coming from one cylinder or all, that will help narrow it down to a bad COP/plug, or something else.
could also be you throttle body, except I think you would notice this problem more than just on 90+ degree days if it was, however it might be worth a shot to try to clean the throttle body either way. this should also more air to get into the engine, allowing more combustion, and less chugging.
question; Does it chug on you only at when you are idling and going at slow speeds, or is it while you are at cruising speeds too?
AR
AR
351Cleveland C4
06-17-2015 11:06 PM
ohmyf150
15
02-20-2013 03:19 PM
navistar82
15
06-11-2009 12:39 AM
tsquared
09-25-2006 07:05 PM
automailcarrier
02-22-2004 10:08 PM
