Code - PO 732 - Ford Truck Enthusiasts Forums
Code - PO 732
Old 08-06-2008, 11:39 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE.a-rod is gaining momentum as a positive member of FTE.
Code - PO 732
Read the codes on my truck today for the heck of it, came up with PO732, which is a 2nd gear ratio error. Anybody know what this means? Tranny seems to be shifting fine.
Old 08-07-2008, 07:19 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Here's what the book says.
P0782, P0732, P0733
SSA, SSB or Internal Transmission Components 2-3 shift error.
Engine rpm drop not detected when 2-3 shift was commanded by PCM. Incorrect gear selection depending on failure mode and transmission range selector lever position. Refer to the Solenoid Operation Chart. Shift errors may also be due to other internal transmission concerns such as stuck valves or damaged friction material. May flash TCIL.
Old 08-07-2008, 09:51 AM
a-rod's Avatar
hmmm.. thanks Chris, is this something I should worry about, or just keep driving?
Old 08-07-2008, 09:52 AM
F350-6's Avatar
I've got a stick, so no experience with the auto's other than what I read here. Sorry.
Transmisson Code PO732 andstal Escape & Escape Hybrid 5 09-10-2014 09:09 AM
2002 Explorer with PO732 Code PanthersFBMama Explorer, Sport Trac, Mountaineer & Aviator 2 08-12-2012 08:22 PM
Check Engine Codes---Help!! kristilynne612 Explorer, Sport Trac, Mountaineer & Aviator 14 01-14-2010 12:12 PM
99' F350sd 7.3l Dtc C1446 centralvalleyequip 1999 - 2003 7.3L Power Stroke Diesel 4 12-15-2006 11:32 AM
Trans not shifting and codes JPR2300 1999 - 2003 7.3L Power Stroke Diesel 9 11-20-2005 01:21 AM
Tags
1999, 2002, 73, 732, 99, code, diesel, error, f350, ford, gear, po, po732, powerstroke, ratio, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
