Ford is slowly turning die-hard diesel power truck enthusiasts into science nerds.
You say that like it's a bad thing?! Long gone are the times of simple mechanics. I wouldn't go as far as science nerds, but at least Ford likes their owners to be educated!! Well... for the most part...
Anybody know at what temp the urea & water mixture will freeze?????
__________________ Light travels faster than sound. That's why some people appear bright until you hear them speak.
02 F-250 4X4 CC,HPSSX, 6637, straight pipe & prediator on tow tune, 93 E-350 Class C motorhome 7.3 Hypermax turbo kit 11,980 gvw
No auto company wants well educated customers, they want suckers to buy new trucks that get 10 MPG.
While this definitely isn't fords fault, Long gone are the times of simple mechanics is right.
I still find guys that offer to help someone fix there car, and once the hood gets popped, their like "Oh, you have one of those new EFI setups... you better take it to the garage."
If the 6.7 gets piss poor mileage like the 6.4, it will be harder yet to override the emissions system, cause the computer measures the EGT's, temps' etc and can sense if urea isnt being burned, and will put the engine into limp mode as a penalty to the driver. It is possible to say yet, but performance modules for the 6.7 may come as a complete drop in replacemnt for the original PCM. I really don't think the EPA or govt will allow loopholes for programmers etc to be able to disable the emmission crap, its getting too serious now to imagine them leaving a possibility as such.
Diesels have 2 more dangerous emissions, Nox and soot. The DPF resolves the soot problem, and the urea will reduce the Nox problem. Problem is, IMHO that the urea will reduce combustion temps and cause the regen cycle to drag on for longer yet, as well as the pain of extra maintenance associated with urea, it gets -40 here and urea wont be flowing to quickly.......do you think people will spend money fixing or upgrading the urea system, or mod their truck and rid it of all the emissions BS????
I dont mean to be nagative here, but it just seems that this is where its going...
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
I used to be like that with the EFI until i tore one apart and just went at it, still very simple stuff, even my diesel once I get working on it is no problem. I just don't have the space to do some of the things or the proper tools otherwise I'd be doing everything to my truck, instead of paying somebody to do it
I could have sworn urea was injected straight into the exhaust, and not into the engine? So there is no way it can reduce combustion temps. Anyways, the 6.4 ALREADY HAS an EGT sensor, various other temperature sensors, and pressure sensors.
There is no way you can completely lock out the PCM, because updates still need to made to optimize and perfect the exhaust system. That means as long as ford can tweak settings at a later date, so you can you.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
I didnt realize the urea was injected into the exhaust...
I have a feeling though, that it may be getting more and more difficult to mod the newer trucks.... and possibly more testing too, to see it you pass emission regs.
__________________
Basically there are two 2010 emission strategys;
1. Use more EGR and keep the engine from creating the NOX.
2. Inject urea into the exhaust stream to break down the NOX after its been created.
__________________
2004 E-450 6.0 137,500 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
Actually you can not get the CAT in in the F-650/750 at this time either. Ford issued a stop build on the CAT's a couple of weeks ago due to emissions/regeneration issues. The only engine offering for the F-650/750 at this time is Cummins and will more than likely stay that way for a while.
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
Good to know Thanks.
__________________ Adam - - Collision/Refinishing Tech
