Fresh frame and rear suspension?
Ok... I got a fresh '55 frame for my '56 yesterday... Spent more in diesel fuel than the actual frame but thats for another forum...
I'm 95% sure I want to put a 4-link in the rear for strength and ride quality. I'm planning on running a 460 and abusing it when the need arises...
Am I heading the right direction? What company would you go with for the 4-link?
Thanks,
JB
Thanks,
JB
Jason Thorbecke at Suicidedoors.com will hook you up. I designed a 4-link triangulated suspension for my 56 and he built it to spec. I can send you the drawings if you wish. The beauty of a triangulated setup is that there is no panhard bar. Thorbecke also has a full line of airbag bracketry and equipment.
I have the shockwave 8007 and universal triangulated 4-link which I am installing in my '56 F-100. If time is not of the essence and you have a little patience I will document the install beginning this weekend and let you know how it goes.
The whole setup was something in the neighborhood of $1200 (including a schrader valve kit for airing before installing the valves, tank, compressor, etc...).
Mine was like $850 7 years ago. 2 upper arms (since redone), and two lower arms, 2 airbags, 2 upper bag mounts. and some air line & fittings.
valves, compressor, switch extra. ($200)
if you use ONE set of valves left/right, then make sure you have a sway bar to stop the side to side movement of air from one bag to another (I didn't think of that!..)
Sam
Sam
