Fresh frame and rear suspension?
The Shockwave 8007 is a bag and shock all in one instead of separate bag and shock. Mount points are on the lower arm mount bracket and on a cross member in the frame. Maybe that was why it was a little more expensive. It will end up looking like a triangulated coil over setup when finished.
I opted for the 'all in one' unit for simplicity sake. I don’t have the tank, valves and compressor yet so I will be using the single air line and adapting a sway bar to the rear end for now. I am looking at the 'air pod' for simplicity sake. 4 airlines, a small wiring harness and controls on the dash with ride height control. It looks good enough to mount in the bed under a cover of sorts.
I may leave the sway bar after getting the air pod or equivalent.
VaHkGuy
1999 to 2016 Super Duty
11-12-2020 06:58 PM
