Need some help guys
Need some help guys
Hey hows everybody doing. I need some help on my distributor for my 460. I pulled it out and am now putting it back in. But i need advice on how to go about installing it in the right postion for timing. I know the firing order an the numbers for the right an left block. But need to know how to get this thing installed in the proper position so I can get the motor started an timed right. Any help would be appreciated. Thanks fellas for any help you can give me its much appreciated.
Bring the #1 Cylinder to the top on the compression stroke. Top will be or should be when the timing mark on the crank is on TDC. Set the dist, rotor on the #1 plug wire position & set it in. Then check to make sure you hit #1 by rotating the engine around if it lines up on #1 you should be set.
