Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-05-2008, 11:23 PM
Third Coast Third Coast is offline
Third Coast is starting off with a positive reputation.
Where to purchase a 226 head.
I'm thinking the head on my truck is cracked. It is still running O.K. but I have a small coolant leak coming right out of the top of the head. Where might I find a new head. I thought I saw some a couple of years ago on the net but I have been unable to find them again. Any help or direction would be appreciated.
  #2 (permalink)
Old 08-06-2008, 06:41 AM
petey shoes petey shoes is offline
petey shoes is starting off with a positive reputation.
is it leaking around a head bolt? might just be a head gasket. did engine freeze solid enough to split head? or get way too hot that it warped? or did you retorque head without reason? considering your location, i bet it got too hot and just needs a little machining to straighten out.
  #3 (permalink)
Old 08-06-2008, 06:55 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
OHA6050 .. 226 Cylinder Head
Internet parts search: There's exactly one NOS (new old stock) 226 head listed among the 4,500 Ford & Ford obsolete parts dealers in the US & Canada.
Obsolete Ford parts dealer greensalescompany.com has one. 800-543-4959
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #4 (permalink)
Old 08-06-2008, 08:53 AM
Thanks for the help. I had head gasket problems a couple of years ago so I replaced the head gasket, used sealer on the bolt threads and torqued it per spec. The leak has been there since about that time. It has ~2000 miles on it since then and is running fine. The leak is on top of the head in an open area not around bolts. A small amount of coolant accumulates and then runs into the indentions around one of the plugs. I currently have the transmission out to have it gone through, one of the shift forks broke a couple of weeks ago. I thought that while the truck was out of commission I might work on the head leak as well but wanted to make sure I could find the part if I needed it. Thanks again for the reply.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
