What's the direction of flow through heater core?
From the firewall side, which one is the inlet and which is the outlet back to the water pump, or does it even matter? I can't remember which one is which. My concern is that there might be some sort of check valve in it to prevent backward flow through the heater core and I wouldn't know it until I needed heat. In my haste and disgust when removing the 7.3, I forgot to mark the hoses. Can anyone help?
My hoses are side by side. I was thinking there is some variation in this between trucks.
That's perfect! That will work out well since the supply on the Cummins is further toward the middle. Thank you for the info. Check another item off the list!
1985L8000cat3208
07-17-2016 10:12 PM
LARIAT 85
07-16-2013 11:44 AM
