What's the direction of flow through heater core? - Ford Truck Enthusiasts Forums
Old 08-05-2008, 10:22 PM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
From the firewall side, which one is the inlet and which is the outlet back to the water pump, or does it even matter? I can't remember which one is which. My concern is that there might be some sort of check valve in it to prevent backward flow through the heater core and I wouldn't know it until I needed heat. In my haste and disgust when removing the 7.3, I forgot to mark the hoses. Can anyone help?
Old 08-05-2008, 10:31 PM
clux's Avatar
clux clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
The upper hose on the firewall goes to the water pump,that's got to be the inflow.
Old 08-05-2008, 10:35 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Supply is on the right, return on the left looking from front of truck. No cv's that I'm aware of , and I've 'messed' with my heater hoses quite a bit!
Following your progress, btw. Keep up the good work!
You rock!
Old 08-05-2008, 10:39 PM
The hose to waterpump is return. But that ain't gonna help - he does not have an engine in there... , or if he does it has 2 less cylinders!
Old 08-05-2008, 10:55 PM
clux's Avatar
Quote:
You are correct, that is the return.
Old 08-05-2008, 11:07 PM
jtharvey's Avatar
Quote:
My hoses are side by side. I was thinking there is some variation in this between trucks.
That's perfect! That will work out well since the supply on the Cummins is further toward the middle. Thank you for the info. Check another item off the list!
Heater core question??? High Flow or Standard 1985L8000cat3208 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 07-17-2016 10:12 PM
Heater control Valve ? ExBeast Excursion - King of SUVs 0 07-13-2016 04:24 PM
Heater Valve LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 07-16-2013 11:44 AM
Replacing heater core Rob Cuenin 1973 - 1979 F-100 & Larger F-Series Trucks 17 03-10-2013 11:47 AM
Heater Hose Routing/Water Flow granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-16-2011 07:38 PM
Tags
1994, 1997, 2000, 58l, 73, 73l, core, direction, f150, f250, f350, flow, ford, heater, inflow, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
