Body mount squeak!
Body mount squeak!
Hi all, I recently upgraded from my 98 Expedition to a 02 Excursion V10. Since purchasing it the right body mount under the front floor squeaks when beginning and ending momentum, both foreward and reverse. I tried lithium grease, wd-40, and penetrating lube. I also had a mechanic check it out, he said it was in good shape and he loosened it, jacked the body up and lubed between mount and body and re assembled. Squeak dissappeared for a cou-le weeks but is back. Would aftermarket poly body mounts solve this and are they available and where. Or would I be better off replacing with new stockers. Any help is appreciated.
SchwartzStock
04-17-2017 04:11 PM
spdmpo
13
05-28-2010 10:17 PM
