Ignition lock turns with ANY key?
1995 F-250 PowerSmoke 4x4 5-speed, 145,000-ish miles
My wife just picked up the truck (no, not literally!). Dealer inadevertently gave us the second key from a different truck (what are the odds, they had TWO midnight blue '95 F250 regular cabs on the lot!). Key cuts are TOTALLY different. Only the "right" key will open the doors. But either key turns in the ignition. Eek!
I did a few searches, and didn't find anything exactly like this. I did find some references to the ignition lock turning with NO key. That's not the case here.
I frequent a "counterpart" Saturn forum, and evidently this is endemic to older Saturns (a factor in why they were one of the most stolen cars several years back). Some folks have reported some improvement with dry graphite-type lubes, or powdered mica (from a gun shop). Has anyone here had this happen, and tried any remedies like this (or any other)?
No, we just picked the truck up last night (hit that near-tornado storm outside Chi.). I was thinking the tumblers might be pretty worn. But like I said, it doesn't turn all by itself; it needs A key in it.
Maybe you're onto something; they're worn or stuck, to the point where just one tumbler needs to be set by the key in order to turn. And that other key happens to match on that tumbler. I just talked to a guy at Kayser parts here in Madison, and he said that the ignition cylinder uses only part of the key cut, only 3 or 4 of the tumbler positions. And the door uses other positions. So it's possible this key, although it's wrong for the door, could be "right" for the ignition cylinder. This is starting to make sense, because I tried one of the keys from her '83 F150 in it, and it slid in, but did not turn the cylinder.
If it has lot of wear/miles, I bet that's what it is. Simply excessive wear. Mine was the same way; someone already replaced the ignition cylinder [was a fleet truck, so a lot of use]. My ignition key doesn't work on the doors. The locksmith's say does make sense. You never see much difference between the cuts of keys.
When I replaced my ignition cylinder, I got one from AutoZone. The first one the guy brought out looked a little worn. So I asked for another. After I installed it, I tried my old key and it fit. The new keys and my old key were the same cut. The new keys wouldn't open the doors as there needs to be more cuts up higher on the key for those tumblers.
$5500. Usual rust for the vintage / latitude. No cataracts. Clean; good but not excellent maintenance (LF U-joint has a LOT of play, etc.).
Time to start researching a starter/ignition kill, methinks....
A WORN, NEW cylinder at AutoStoned? Eek! Yeah, I noticed the same thing with the two keys, which part had the same cuts, and which were diff. A bit unnerving, how little it takes to hotfinger these trucks.
Thanks for the info, folks.
The tumbler part wasn't worn. The black paint on the outer part was chipped. If I would have taken that one, my key would not have worked. The replacement key and my old key had the same cut on the end. The upper cut is for the the doors. The new key only has the ignition cut into it, not cut for the doors. Could take to locksmith and have him cut the door section into new key to match.
Tylus
2004 - 2008 F150
74
10-25-2019 02:18 AM
VolvoMatt
10-09-2013 11:43 AM
bma2001
1999 to 2016 Super Duty
09-02-2013 09:25 PM
