Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #1 (permalink)
Old 08-05-2008, 03:13 PM
94MustangGT's Avatar
94MustangGT 94MustangGT is offline
1996 Ford F-150
94MustangGT is starting off with a positive reputation.
Question 95 Aerostar A/C Issues
Im having some problem with the A/C on the van, I would assume its a vaccum issue. Sometime the the A/C will cut off and wont cut back on unless you turn it off then turn it back on. Last time I checked, it had enough R134. Where should I start looking? Any insight would be great.
__________________
96 F150 XLT - RC/SB - 351 - E4OD - 4X4 - 3.55's w/LSD - Handling Package - Tow Package w/Super Cooling - Warn Manual Hubs - 31" BFG AT's
94 Mustang GT - 302 - T5 - Black on Tan - Bullitt Wheels - 1/8th Mile = 9.2 @ 77.4
American Made
  #2 (permalink)
Old 08-05-2008, 05:09 PM
bertha66's Avatar
bertha66 bertha66 is offline
1966 Ford F-100
bertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to allbertha66 is a name known to all
I have problems with my 90 Aero's A/C, it stems from the vacumn valve that is in the dash passenger side, next the the speaker. Sometimes the vacumn will not move it and the valve defaults to putting the air out the defrost vents.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1976 F250 4X4 Custom with 429
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 08-06-2008, 12:37 PM
1996 Ford F-150
^ Thanks man, I was looking today and found a broken vaccum line under the hood, so hopefully that will fixthe fan issue and cutting on and off.. Now if I could just get it ice cold, we will be good to go.
__________________
American Made
  #4 (permalink)
Old 08-06-2008, 12:43 PM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
Garage is empty, add now
96_4wdr is gaining momentum as a positive member of FTE.
parts affecting "icy cold" on Aero a/c
run on MAX a/c, cuts off all outside air if input door is working correctly
blend door leaking. sticking, seal failed, weak vacuum
worn out a/c compressor
cycle switch or compressor clutch failing
plugged orifice filters
low a/c charge. need a/c gauge set to properly charge.
bug plugged condensor
failed fan clutch
  #5 (permalink)
Old 08-06-2008, 01:24 PM
cookkd cookkd is offline
cookkd is starting off with a positive reputation.
failed fan clutch
.....add to the above:
Dirty/plugged evaporator core.....really cuts down on the amount of cold air that blows out of the vents.
__________________
"Alcohol, Tobacco & Firearms should be a Convenience Store and NOT a Government Agency!"
  #6 (permalink)
Old 08-06-2008, 03:00 PM
1996 Ford F-150
^ I think it got a reman. compressor and a new evap. core last years. Im not sure though, it my parents van.
On the bright side, the vaccum issue is fixed and I Sea-Foam'd the heck out of the motor. Nice smoke show. hahaha
__________________
American Made
  #7 (permalink)
Old 08-06-2008, 09:18 PM
aerocolorado aerocolorado is offline
aerocolorado is gaining momentum as a positive member of FTE.aerocolorado is gaining momentum as a positive member of FTE.
On paper, an A/C system is a simple matter of physics, but to make it work requires at least a dozen different components that must all work in perfect harmony. One weak or damaged part can disrupt the entire system and make troubleshooting a nightmare. Sometimes you are dealing with two or more problems simultaneously which greatly compounds the difficulty in figuring out what is wrong.
From your inital description and adding to what 96_4wdr listed, your system could act like that if it is overcharged. There is a fine balance between too little and too much r134a and as mentioned gauges are the only way to know whats going on inside. What you describe could also be intermittent freeze up of the evaporator core, especially if you live in a humid climate. The core ices over, blocks air flow and suddenly no A/C. When you turn off the van (and A/C) the ice rapidly melts and the A/C magically works again.
Unless you have considerable time and money to chase down an A/C problem, the best bet is to let a qualified A/C specialist tackle it. They can diagnose in minutes what would take a first timer days or weeks to figure out. There is also another FTE forum on Heating and Air conditioning. You might want to check out some of the problems people are posting over there just to get an idea of what all is involved in A/C repairs.
  #8 (permalink)
Old 08-06-2008, 10:12 PM
1996 Ford F-150
^ Thanks, how would you go about "draining" some R134? According to the gauge on top of a 134 recharge can, shows it to be slighty overcharged. The compressor does not cycle on and off. Thanks again
__________________
American Made
  #9 (permalink)
Old 08-07-2008, 08:14 AM
The correct method is to recapture it. However, this requires specialized equipment only A/C shops have. Of course, leaky A/C systems vent directly to the atmosphere.
An overcharged system will not cycle. Cycling times are temperature dependent. At ambient temperatures above 90 degrees, the system will infrequentlly cycle, it at all. Simple huh?
  #10 (permalink)
Old 08-07-2008, 05:52 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
It's possible for you to capture some of the stuff yourself, but you will be working with high pressure liquids.
The output of the condensor is high pressure liquified refrigerant, and you can tap it from the schrader valve with a metal tube, run it through a bucket of cold water to help keep it cool, and feed it into an evacuated container, also kept cool. Use the compressor to keep generating the pressure until it equalizes with your container, or until the system is drained enough that the pressure switch no longer turns on. It might take a couple of containers if you don't have an external compressor that's sucking the refrigerant out of the system.
  #11 (permalink)
Old 08-08-2008, 02:54 AM
DCRB DCRB is offline
DCRB is starting off with a positive reputation.
you can't just let it blow out into the air? i remember i broke the AC line on a friends wrecked corolla trying to get the rad out... he had bald rear tires, hit a bump, and "drifted" into a rock. the tube started hissing...
__________________
88 civic hatch - rebuilding from the ground up, too many mods.
90 civic sedan - daily driver in the works
95 4.0l 2wd xlt base - old reliable turn key family savior
  #12 (permalink)
Old 08-08-2008, 04:59 AM
96_4wdr's Avatar
would you want me pouring my old antifreeze glycol into the Bull Run water supply?
  #13 (permalink)
Old 08-08-2008, 09:53 AM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Water and refrigerant do not mix.
  #14 (permalink)
Old 08-08-2008, 07:01 PM
Quote:
Of course not. But if you read my post carefully, I was describing a cooling system where you run the metal tube through a bucket of cold (ice) water to keep it cool on its way into the collection container. In fact, get several feet of copper gas line and coil it so it fits in the bucket, then fill it with ice water. By the time the fluid reached the container, it should be cooler and lower pressure.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
