hpop guage question
hpop guage question
First off does the OBS PSD have a separate HP oil pressure guage, dummy light or engine code. Also is an hpop oil pressure guage an option or popular upgrade or both? Also does the low pressure oil pump on the bottom of the engine have a seperate guage, sending unit?
First off does the OBS PSD have:
a separate HP oil pressure guage (No)
dummy light (No)
engine code (Only when not within spec)
Also is an hpop oil pressure guage an option (Not from the factory)
popular upgrade (Only if you want to know the psi or you're troubleshooting)
Also does the low pressure oil pump on the bottom of the engine have a seperate guage, sending unit? (Yes, the sending unit is on top of the hpop res, its only a switch so the dash gauge only reads half scale or zero)
Sorry my browser wont let me change color of the font.
dummy light (No)
