Will NOT idle! - Page 8 - Ford Truck Enthusiasts Forums
Will NOT idle!
  #106
Old 02-12-2012, 05:56 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Quote:
Originally Posted by PRIMERED79 SHORT BED View Post
Is D5AE AA a 2100 or a 2150?
If the choke pulloff is in the air horn, mounted vertically behind the choke tower, it's a 2100. If the choke pulloff is mounted horizontally on the passenger side external to the carburetor, it's a 2150.
  #107
Old 02-12-2012, 06:18 PM
OldStyle's Avatar
OldStyle OldStyle is online now
Rusty Roller
OldStyle has a good reputation on FTE.OldStyle has a good reputation on FTE.
the choke still wont open all the way.
Are you sure you have the choke spring inserted it the slot in the linkage arm?
  #108
Old 02-12-2012, 08:08 PM
PRIMERED79 SHORT BED PRIMERED79 SHORT BED is offline
PRIMERED79 SHORT BED is starting off with a positive reputation.
Yes I made sure the spring was in the fork, I double checked it.
I just noticed in the pic you just posted that it appears to have a piston in the vacuum hole, do the 2150 have that?
Because mine doesn't.
  #109
Old 02-12-2012, 08:32 PM
fmc400's Avatar
MSEE
No, a 2150 will have that sealed off. That's just left over in the casting from when the pulloff was in the choke housing itself, in the days of the ancient Autolite 2100 series carbs.
  #110
Old 02-12-2012, 08:48 PM
Ok good thanks.
  #111
Old 02-12-2012, 08:49 PM
OldStyle's Avatar
Rusty Roller
That pic was just to show the fork. My book doesn't show a piston.
Edit: Took me too long to confirm.... Thanks fmc400
  #112
Old 11-22-2012, 08:59 AM
coondog41 coondog41 is offline
coondog41 is starting off with a positive reputation.
1979 2150 carb
great info do have choke working properly now. engine is a 302 v-8 thx all
  #113
Old 06-24-2013, 04:35 PM
fiveofsevin fiveofsevin is offline
fiveofsevin is starting off with a positive reputation.
Re:
Ah, its my turn now. 302 2bbl 2150 carb, wont idle. truck ran like a champ until a couple daze ago. cant find any vacuum leak, idle circuit in carb is clear. Grrrrrr.
97 7.3 Powerstroke Dies while Driving twice had to be towed WoodBoss 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-01-2015 10:39 PM
88 ranger 2.9L idle issue McStein Ranger & B-Series 8 03-18-2015 10:26 AM
Bitten by p0174. Need help chev2ford 1997 - 2003 F150 19 10-24-2014 11:31 PM
84 351 W Carb sensor problem.. Seth_84F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 12-17-2013 09:22 PM
78 F100 - Seafoam'd jaro007 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-25-2011 09:41 AM
Tags
2150, 2v, 302, 360, 73, adjustment, carb, carburetor, f100, fast, float, ford, id, idle, level, motorcraft, setting, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
