Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-04-2008, 10:24 PM
jjlrrw is starting off with a positive reputation.
Towing R&R Sno-Fire trailer
I will be towing a 12' plus v-nose R&R Sno-Fire trailer this winter, trailer is 1300# sleds 600# each, three in the trailer one in the bed of the truck.
http://www.fentontrailersales.com/rn...fire-large.jpg
'05 SC 6.0 PSD stock, I was wondering if anyone has this combination and what MPG I should expect to see. My '01 F150 4.6l was at 9mpg.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-04-2008, 11:26 PM
buckweet1980 is starting off with a positive reputation.
heh, honestly the truck probably know its there.. i have a 3000lb 20ft trailer and i only saw a 1 or 2 mpg drop at normal cruising speeds when transporting the trailer (empty)
  #3 (permalink)
Old 08-06-2008, 02:54 PM
daddgonemadd is starting off with a positive reputation.
I own a R&R enclosed 16' v-nose, 6'6" interior height. It should be very close to your rig. If you drive REALLY slow and careful you might see 13mpg. If you set the cruise at 72 you should get 11mpg. If you got 9 in the F150, then you drive slow and careful.
  #4 (permalink)
Old 08-07-2008, 09:14 PM
liv liv is offline
liv is starting off with a positive reputation.
get an egt gauge if your going to be towing that thing through the mountains with the stock exhaust you will most likely be seeing some high egt's.
__________________
-03 F250 FX4 Lariat Crew Cab, 6.0, Edge with attitude, turboback 4" MBRP with 8" tip, AFE CAI, 6" Fabtech lift, 35" Nitto Terra Grapplers, 18x12.5" Weld Cheyenne wheels, Autometer Pro-Comp Boost and Pyro, Westin Bull Bar
Quote:
Originally Posted by orangebyke View Post
I dont know but as odd as it is, when it appeared, money started flying out of my pocket. there must be some connection there
  #5 (permalink)
Old 08-07-2008, 10:18 PM
fordboy2 is starting off with a positive reputation.
jjlrrw, you must be from MIchigan?(the fenton trailer sales thing) My 06 got 10-12 last winter pulling my 4place enclosed flat front snowmoie trialer with 4 sleds in it from Saginaw to houghton lake if that gives you an idea. Speeds were 65-75 most of the time. Even pulled it back from there in 4wd due to slushy/icey roads once and got the same mpg probably at a slower speed though I think!
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
  #6 (permalink)
Old 08-07-2008, 11:07 PM
Quote:
Yea from the Grand Rapids area I need to update my profile, I just found that pic doing a google search and posted it as my trailer is similar. I was hoping for better but it is what it is, at least I can haul 4 sleds so the cost is /4. We go to the east side and ride out of Paradise or Seney most of the time.
Thanks
  #7 (permalink)
Old 08-07-2008, 11:09 PM
Quote:
No Mountains for me at least not this year, thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
