1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Mini Spring pack leveling kits
Old 08-06-2008, 08:24 AM
TXHillCountry's Avatar
TXHillCountry
TXHillCountry is offline
I'll second (or third or fourth, whatever reply this is haha!) the Icon (Donahoe) mini spring pack.
Straightforward to install, using stock shocks, etc.
Here's my .02 on installing them: Get the front of the truck up as high as is safely possible. Use two heavy duty jacks to lower the the axle down with. Before you go to lift the axle back up, check the diameter of the heads of the new centering pins. Mine were slightly too large for the stock holes on each side and required a little grinding to make fit. As you go to lift the axle back into place, it can be a $#%$ to get the pins to line up with the holes. I used about 4 "ratchet-straps", two on each side, to help pull and yank the axle around to get the pins and holes to line up.
rgds,
TX
Old 08-06-2008, 09:55 AM
Rockindoc's Avatar
Rockindoc
Rockindoc is offline
Thanks
Thanks for the helpful info TX!
Old 08-06-2008, 12:37 PM
DCSpecial's Avatar
DCSpecial
DCSpecial is offline
Originally Posted by Rockindoc
DC, thanks for all your help. I'm looking forward to putting your kit on my truck. Oh BTW, I sent you a PM.
Glad to help, your mini spring pack shipped out yesterday.
Originally Posted by cartmanea
DC, you're awesome as always.
Thanks
Old 08-12-2008, 01:20 AM
Rockindoc's Avatar
Rockindoc
Thanks!
Hey DC,
Got the mini spring packs today. Thanks for the lightning fast service. I'll probably install this weekend or next. I'll let you know how it goes. Thanks again.
Old 08-12-2008, 09:44 AM
DCSpecial's Avatar
DCSpecial
Cool, thanks for the business.
Old 08-15-2011, 12:16 AM
Castawayf250's Avatar
Castawayf250
Castawayf250 is offline
The Icon kit (used to be Donahoe) is good, beware of the cheapies on Ebay.
Why do you suggest that we stay away from the ebay kits?
Old 08-15-2011, 06:59 AM
TXHillCountry
I think the advice is to stay away from "no name" brands. There are some fairly inferior kits out there, in terms of quality of the materials. I don't think many people mind spending a few extra dollars on something that literally holds up the front of your truck.
Old 08-15-2011, 07:28 AM
jdboy's Avatar
jdboy
jdboy is offline
Maxx Lift 2.7"
I used this kit I purchased off of ebay and have been more than happy with the results. I done a thread on this and the rear lift block conversion, I'll try to find it for this thread.
And yes I need to break out the spray can !!
Old 08-15-2011, 08:17 AM
Castawayf250
Right now, I have 3" blocks on my front axle. I know this is idiotic, so don't start attacking me about it. That's why I'm getting a mini pack.
The reason I have Blocks is because I took shackles to a shop to be installed, they installed them, then found out they wouldn't work, so they convinced me to do blocks, and since they already charged me for the shackle installation (even though they were coming off) I just decided to get the blocks because I wanted my truck back. So I'm now going back and putting mini packs in. And I need 3" so I think I'm gunna go with a company called "proform fabrication". I found them on eBay, but they have a site and they're the ones who make the shackles I bought, so I know they're made with strong materials.
http://proformfabrication.com/catalo...roducts_id=122
Old 08-15-2011, 08:27 AM
knightrider955's Avatar
knightrider955
knightrider955 is offline
Pro Form Fabrication
So you bought shackles from proform and they wouldnt work? And now your going back? Whos to say the blocks will fit? They couldnt get it right with the shackles.
Old 08-15-2011, 02:42 PM
Castawayf250
If I'm not mistaken, the shackles don't work because my truck doesn't have the stock springs. I talked to my local lift expert (not the idiot who put the blocks on) and he understood that why the shackles didn't work, said I could live with the blocks as long as they're not aluminum, and said that proform's mini packs are legit. So I'm gunna go with the mini packs. I'll post on here what I think about them.
Old 02-15-2012, 06:44 PM
black_silver_95s's Avatar
black_silver_95s
black_silver_95s is offline
After installing the mini spring pack, an alignment is still needed right? or not?
Thanks
  #28
Old 08-21-2021, 09:21 PM
Jesaiah Azares's Avatar
Jesaiah Azares
Jesaiah Azares is offline
Question
I want to lift my truck 3 more inches it is level right now so my plan is to buy a 3 inch mini pack for the front,BUT I would also like to buy another one for the rear it seems safer than a block.Is there any reason not to put one of these in the rear?
irockstar661
03-19-2015 10:21 AM
cclgeo
10-13-2014 11:21 PM
Poorboy04
03-07-2014 03:14 PM
rickdavis81
07-01-2013 09:27 PM
That_Guy
20
05-19-2009 10:11 PM
Quick Reply: Mini Spring pack leveling kits
