Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 08-04-2008, 04:27 PM
rebocardo rebocardo is offline
Garage is empty, add now
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
pool liner reinstall?
Someone asked me to help them reinstall their above ground pool liner. Basically the pump broke, it got filled with branches and junk. So, it was drained and cleaned.
But, now the liner has pulled away from the pool after the pool/liner has been cleaned. To me it feels sort of hard and I am thinking if it is filled with water, it will not squish back into place, but, crack from the weight of the water.
Am I correct or will it just push back into place once water is added?
__________________
The Year 2010 Anno Domini - May it bring a great year of Revelations to you.
Libraries are like art museums for the printed word.
Bronco IIs and 4x4 E-series -
the best Fords, because I own them!
  #2 (permalink)
Old 08-04-2008, 07:44 PM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.FTE Herman has a spectacular reputation.
I though a shop vacuum used on the 'outside' of the liner was used to pull out sags and wrinkles.
But I do concur, if the liner is to stiff, it might crack.
__________________
Business: an ideal predicated on the money-making notion that there are no human beings, just human resources.
  #3 (permalink)
Old 08-04-2008, 09:41 PM
modar modar is offline
modar is gaining momentum as a positive member of FTE.modar is gaining momentum as a positive member of FTE.
I would go with a new liner and get a cover for the pool. Too much time and water involved to take a chance.
__________________
Certain things should just stay as they are. You ought to be able to stick them in one of those big glass cases and just leave them alone. - Holden, 'Catcher in the Rye'.
  #4 (permalink)
Old 08-05-2008, 06:49 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
When a liner gets stiff it becomes brittle and you will be fixing leaks all the time. A new liner feels nice and flexible like a thick kiddie pool.
I played this game with a worn out liner for a couple years and it cost me hundreds of dollars in lost water. An old liner will probably push back into place with a full load of water, but it may be uneven and my experience is that it will be leaky and develop new tears.
Good Luck,
Jim Henderson
  #5 (permalink)
Old 08-06-2008, 03:15 AM
Thanks guys, that is what I thought.
Trouble is the guy is retiring and selling his house and can't or does not want to afford to fix it with a new liner, especially in this depressed market. Last two years houses here have lost an average of 17%.
Trouble is unfilled it is a worse liability. I might try the wet and dry vacuum to suck it back in.
__________________
  #6 (permalink)
Old 08-06-2008, 10:08 AM
durk's Avatar
durk durk is offline
durk is starting off with a positive reputation.
been here before. The liner pulled away and when we filled it back the side of the pool buckled. We picked up another liner at the local pool supply and all my problems went away.
  #7 (permalink)
Old 08-06-2008, 09:55 PM
924x2150's Avatar
924x2150 924x2150 is offline
924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.924x2150 has a good reputation on FTE.
price the liner..above ground pool liners aren't that bad. I hope the pool isn't too big. Better yet. sell the pool to a scrap yard...i.e. good prices for aluminum scrap these days. Pools rarely increase the value of a house, especially an above ground older pool. Pools are a very big pain in the butt and many prospective home buyers know this, and don't have the desire to have a safety hazard in the back yard.
Any way, liners can be destroyed by improper water chemical balance. 2 years ( or less) of poorly maintained water balance ( pH, alkalinity , etc.) can stretch or damage a new liner. If the liner is close to 10 years old it has probably seen its last season also.
New liners are installed by preparing pool walls, raking and brushing out floor flat (remove stones, sticks etc.) re-sand floor if needed. install liner, attach bead to top coping, fllatten out as water is poured into bottom, correct wrinkles before pool is full. I watched my neighbor install his 24 x 16 square ester williams liner in about two hours, it only cost a couple hundred.
__________________
1992 F150 XLT 2WD 4.9L w/E4OD
1996 Harley 1200 Sportster XLH
2006 Honda Civic LX
  #8 (permalink)
Old 08-07-2008, 10:30 PM
FordxFour's Avatar
FordxFour FordxFour is offline
FordxFour has a very good reputation on FTE.FordxFour has a very good reputation on FTE.FordxFour has a very good reputation on FTE.FordxFour has a very good reputation on FTE.
If the guy is selling the house, junk the pool. Frankly if I was interested in buying the house the above ground pool would have to go before I signed on the dotted line.
__________________
Marty
Quote:
Originally Posted by Monsta View Post
In 5 minutes someone opened the door, popped the hood, started the truck, broke the heated seats and stole your horn and then just left? Where the hell do you live??
05' X-LTD V10/4.30's_____92' F-250 4x4 351w 5sp.
01' X-LTD 7.3 PSD_______99' F-450 7.3 6sp. Western Hauler
  #9 (permalink)
Old 08-10-2008, 10:20 PM
Thank you everyone, we decided to leave well enough alone after relaying the info. to him.
__________________
Tags
24, atlanta, buckled, cost, forums, ga, liner, liners, pool, pools, pulled, reinstall, reinstalling, scrap, suck, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
