Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-04-2008, 02:25 PM
Phrosut's Avatar
Phrosut is starting off with a positive reputation.
The smell of diesel
I was a cross-country owner operator for a decade starting in the mid-seventies. I had three different tractors, two with Cummins and one with a DD/Allision. All the maintenance and repairs were done by me. The diesel odor was part of the life.
Last month I bought my first diesel anything since the mid-eighties. When I changed the fuel filter a week ago I was mildly surprised that the smell of diesel wasn't nearly as strong as I remember. It also seemed to be much clearer.
Is this because of the Ultra Low Sulfur fuel? I live in California so I assume that's what I get from the pump?
Phil
2003 7.3L SC 2WD
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-04-2008, 02:43 PM
CampSpringsJohn has a good reputation on FTE.CampSpringsJohn has a good reputation on FTE.
You got it. It started to change some years back when they lowered the sulphur to 500ppm. Now it's at 15ppm, so yes, it does have a different smell.
__________________
John
1997 Super Duty, PSD,6637, E40D, Utility Bed, 4" exhaust, custom tuner with high idle, 50hp, & 80hp.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, custom tuner with high idle, 50, 75 tow, 100, 120, & 140
Trying to be the man my kids think I am.
Unfortunately, my wife already knows better.
  #3 (permalink)
Old 08-04-2008, 07:11 PM
parkland's Avatar
parkland is gaining momentum as a positive member of FTE.parkland is gaining momentum as a positive member of FTE.
ULSD sucks, you might wanna add some lubricant additive to the fuel.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
Quote:
Originally Posted by 6686L View Post
I nominate this Parkland guy for President. He KNOWS what is important, has his priorities straight. I mean...if...we are going to have a "pair of boobs in the White House"...at least with Parkland running the place...there will be some that are good to look at...!
  #4 (permalink)
Old 08-04-2008, 07:28 PM
Phrosut's Avatar
Quote:
What's good? "Back in the day" I used Power Service, but that was more for keeping injectors clean than lubrication. I also used to use Siloo but I'm not sure that is even available anymore. Since one truck had an Allison tranny, I'd add the used ATF to the fuel. From what I've read here THAT'S not a good idea for these new engines. I've also seen where people add 2-cycle oil.
I have added Amsoil's Octane Boost to the tank but I don't think that does anything for lubrication.
Phil
'03 7.3L CC 2WD
  #5 (permalink)
Old 08-05-2008, 02:48 AM
parkland's Avatar
I buy the 10$ bottles from walmart, or else (better) large just of special additive from "milligan bio tech", of saskatchewan, and its supposed to be the best hands down, they have test proving their additives are 10x more concentrated than the next leading brand.
I think a 1 gallon jug is 60$, and treats 3500 liters of fuel.
__________________
  #6 (permalink)
Old 08-05-2008, 09:40 AM
I have used additives from amsoil, and I like them. The cetane boost does nothing for lubrication. You also need to use their fuel additive. I have also used wal-marts 2 cycle outboard oil too. That stuff did surprisingly well in a study I saw a while back. It's on this website somewhere. Do a search for diesel fuel additives, you should find it. In fact, I'll try to find it and post it here.
__________________
John
  #7 (permalink)
Old 08-05-2008, 09:45 AM
http://www.ford-trucks.com/forums/66...additives.html
Here's the post. The third thread has the info you will want.
__________________
John
  #8 (permalink)
Old 08-05-2008, 12:19 PM
Phrosut's Avatar
Thanks for the link John!
And where's the best place to buy Opti Lube products?
Phil
'03 7.3L CC 2WD
  #9 (permalink)
Old 08-05-2008, 05:03 PM
Phil
'03 7.3L CC 2WD
A lot of the stuff listed in this study can be found at most truck stops. Be sure you get what you want. If you noticed, some products from the same company did better than others from the same company. Also, if you have a parts house that caters mostly to big trucks, they may carry some the stuff too.
__________________
John
  #10 (permalink)
Old 08-09-2008, 08:53 PM
MexicanScaper987 is starting off with a positive reputation.
I have used Red line oils diesel fuel catalyst a few times. It seemed to help the mpg's a bit. It has help the lubricicty of the fuel and had some injector cleaners in it too.
__________________
Joe
2006 F250 4x4 Reg cab 6.0 PSD/Torque shift
1994 F250 4x4 Reg cab 5.8w/C-6
1988 F150 2wd 4.9L/ ZF5 speed. (Needs a tranny)
Lets go Fishin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
