Running Horrible
Running Horrible
The other day I ran my 96 F350 very low on fuel and switched the tanks at the last minute. It sputtered and then caught back up and ran fine for about 150 miles. While driving it bogged down very hard, like it lost all power, and the check engine light came on. Pulled over, light went off, I checked everything under the hood, looked fine. Now today it is running horrible. I have changed the fuel filter and run a bottle of cleaner through it. Not helping. It starts fine, then sounds like it is gonna die. Very Low idel for about 30 seconds and then back to normal. And this cycle continues. I have worked on many 7.3's but have never seen this. Anyone have any ideas.
I appreciate anything you have.
It could also have plugged one of the fuel lines ,,try blowing them out toward the tank ,with air ...
The code will help if you can retrive it ....
Thanks for the feedback.
I checked the connections at the VC's and they looked fine. When it is running rough and i unplug both connections on the right side both nothing changes. If I unplug just one on the left it dies. However, when it smoothes out and runs right, and I unplug the right side it will die. So everything with the harness and connectors at the VC seems to be working. Checked the fuel lines and they were clean. Im gonna try to change out the IDM off my other 350 and check for a change.
Am I running out of options?
same thing happened to me a couple of weeks ago and it was the IDM. I could pull both VC plugs on teh left side and it didnt change at all. then sometimes it would run finefor about 30 sec then die. My IDM was like a fish tank. Im surprised it ran at all.
