Can I get some input on towing mileage for 7.3 PSD?
I have a 2000 F-250 XLT 4x4 7.3 PSD and I have a few questions about towing mileage...
I have finally got the rig tweaked to where my non-towing milage yields me at least 600 miles highway off of one topped-off 29 gal tank of fuel. The mods used are 4" turbo-back exhaust, Lucas Fuel Treatment, K&N cold-air intake, and Bullydog Power-pup programmer set at the 120 hp setting...
Here's where things don't make sense...I made my first long distance trip pulling my Jayco 293RKS fifth-wheel camper 200 miles. I thought 3/4 tank of fuel would get me the 200 miles easily but I had to fuel up after 150 miles !
So, on the way back I filled her up and took a different route to where I could use cruise control and less traffic, etc. I was able to go 215 miles home and the truck is on absolute EMPTY
Is there anything I can do to increase towing mileage ? I find it hard to believe that my mileage itowing is 1/3 of my non-towing mileage ! What mileage are you all getting while towing ? What am I doing wrong ? Do I try another setting on the programmer ? (50hp, 75hp, or 120hp are the choices)
Any and all input is greatly appreciated !
Thanks !
Scott
Thanks !
Scott
I get a solid 15 regularly, perfectly stock and slightly taller than normal.
I get 13.xx towing anywhere from a car trailer to a car hauler.
You should be getting much better than that towing. The 7.3 doesn't drop off that badly when loaded. it's the main advantage left for having a diesel.
Hmmm, looks like I should try your combo, that is very close to 20mpg unloaded! I could stand a few extra mpg's for sure.
I'd like to get 20mpg empty as well!
I can't help you much, but here's what I do know- no trailer with a dirt bike in the bed I got average 15.5 mpg in my truck- this was running 80mph/2200 rpm freeway and 65mph/1900rpm highway with a few passes on the highway stretch. I don't check mileage often since my tank is around 55 gallons.
Less traffic and cruise control (steady pace) meant more MPG.
As for getting more while towing, your Power Stroke basically makes about 275 HP @ 2800 RPM. To maximize your mileage, you need to keep the tachometer at or below that 2800 RPM figure. This is where your engine makes the best power and gets the best volumetric efficiency.
I'm not familiar with the chip you are running, but you didn't say how fast you were driving. I do know your mileage will drop when you push it over 60mph, and really drop if pushing it over 70mph. Also, if the chip you use is anything like a DP chip, towing in the highest setting could be dangerous. Do you have a set of gauges? If so, how hot were the exhaust temps going up hill? A set of gauges is vital if you are towing with a chip. Boost, tranny temperature, and exhaust temperatures, (most important) are important to monitor.
FWIW- I have a 2000 F350 PSD myself. It has the 6 speed, is stock, and I get 18 MPG in the city, and about 13 to 15 towing my 31' Wildcat. I guess this is about normal.
Have a 2009 6.4 liter coming in November... nice truck, but I'm scared of the milage I might get in that.
Thanks !
Scott
Thanks !
Scott
my truck is a 97 psd, so its a little different than the superduty 7.3. but i was looking at some bully dog chips for mine a while back and it had a 50, 75 and 120 horsepower setting. they had a downloadable instruction manual online and it said for towing heavy loads use the 50 hp mode. for towing light loads under 5k lbs or for mild performance gains use the 75 hp mode. and for performance only(absolutely no towing) use the 120 hp mode. so that could be your problem there. personally i would just run it in stock mode until i hit a big hill and then flip it over to the 50 hp setting until i reached the top. then back to stock mode.
oh yeah. my mileage is 21-23 mpg at 55 mph empty(xl, reg cab, no power anything, 5 speed) and around 19-20 mpg if i run 65. my most recent trip i towed 8k lbs from tennessee to ohio and got 18 mpg running 65 mph the entire trip. im not sure what your trailer weighs, but thats a huge drop in your mpg's. way more than normal.
