Runtime Error?
Runtime Error?
My laptop has developed a strange problem. Right in the middle of searching a website a window pops up with "Runtime Error!," and then NOTHING works right: IE shuts down, e-mail fails to respond, and everything closes. If I restart the computer, it's usually OK, but it can occur again after an hour or so.
Did some research and thought maybe having Earthlink Total Access running in the background was the culprit, but I turned it off and the problem still occurs. Couldn't find anything on the web that was really helpful- one company claims to fix it for free, but all their "Download Now!" links just take me to Netflix movies. Anyone else have this occur, and are there any fixes?
There is probably some embeded script that is being called and your older version doesn't know how to handle it..
Also what version of internet explorer or firefox are you running.. You could try updating that also..
Have you checked for viruses , spyware and the like?
I use Norton on one compute and AVG on the other. Plus I use Spybot on both. I don't run ad aware -- although I probably should.
One other trick I've used is to create a new account and pull anything I want over there. After a while I get rid of the original account. ( I also usually surf with a non admin account unless I'm doing financial type stuff)
Good luck,
Good luck,
Good luck,
Good luck,
I have worked on many pc's that had ad aware and still got infected..
1956MarkII
03-18-2007 10:37 PM
Fordlover55
04-12-2005 02:59 PM
99 ranger bob
27
04-06-2004 10:11 AM
