Major water leak 91 f150 inline 6
Old 08-03-2008, 11:04 PM
Sirdrinksalot's Avatar
Sirdrinksalot
Sirdrinksalot is offline
When i fill the truck up with water is starts to leak a ton of water. I changed the lower hose today that was alot of fun and it still leaks. So any ideas on what else it could be. Here is some other info the water pump makes no noise at all.
Old 08-03-2008, 11:23 PM
andym's Avatar
andym
andym is offline
Well, this might seem like a silly question, but where is it leaking from?
Take it for a drive and shine the flashlight around. See if you can spot the leak. Just because the water pump isn't making noise doesn't mean it isn't leaking.
I would say that about 75% of the time the water pump itself is the source of the leak.
Old 08-06-2008, 12:19 AM
rijrnnr's Avatar
rijrnnr
rijrnnr is offline
Sirdrinks, check the freezeplugs before you go for a new waterpump. That front freezeplug fooled me. You can replace five out of six without removing the exhaust manifold unless it's a 4x4, in which case somebody else will hopefully weigh in.
95PSDieselP
12-08-2010 12:16 PM
Polkster
03-12-2009 04:39 PM
Ford Blue
1966 - 1977 Early Broncos
01-24-2005 12:48 AM
beckandyork
05-20-2002 04:07 PM
Quick Reply: Major water leak 91 f150 inline 6
