Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-03-2008, 10:49 PM
I6lover I6lover is offline
Garage is empty, add now
I6lover is starting off with a positive reputation.
5.4l questions
Im new to lightings and know almost nothing about what options they came with when.
I have a 97 f150 and am considering swapping soe or all of the motor for a lightning motor. did they ever make a N/A lightning that had a 5.4l? Id like to use the intake off of one if they did. Also does anyone know what the difference between a stock 5.4l and a lightning 5.4l internals is?
Thanks for any help!
  #2 (permalink)
Old 08-03-2008, 11:08 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
No. But the Gen 1 L's ('93, '94, '95) came with a n/a 351 Windsor.
Forged internals. But it's all the other stuff that makes a swap less than appealing
It would be easier, (and depending on the year, cheaper too!) for you to buy a Gen 2 Lightning ('99 - '04) than it would be to do a swap. But if your heart is set on it, you need to contact Mike at Madenterprise. He's helped MANY a people with a swap.
http://www.madenterprise.com/scparts.htm
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #3 (permalink)
Old 08-26-2008, 08:00 PM
commandersander's Avatar
commandersander commandersander is offline
2003 Ford F-150
commandersander is starting off with a positive reputation.
Correct Stewart.......
Mike is a WAAAAAY cool guy with no issue when it comes to picking the brain....
I did this with my 97. Looking back, I think it may have been easier to just buy an L but there was this earnest kinship that I have with my 97 3-door 4x4 that I didn't want to let go of...In the long run, I EASILY spent 10k converting my truck....and I got the longblock free from a buddy at Ford.
Your biggest issue is wiring.
Between the SVT cluster and the L computer, you EASILY have 2-weeks worth of wiring full time. Simply buying the L harness won't work for you....the 97 has vac assist for ac control....the L has electronic...the harness is different.
Also, unless your 97 is a CAL emission truck, you have the 4r70w. If so, you need a new trans AND flywheel.
If you have the e40 or 4r100, then you CAN mate that trans to an L motor or continue using it with your bottom end (not recommended) with minimal mods to the harness. (97 OSS and TSS are different than Gen II L)
Also, if you don't already have the e40/4r100....you need a new trans cross member and a new rear drive shaft.....
I could go on and on....but no need unless you plan on doing it.....
I still have all of my pinouts and new harness config....and would be glad to help.....
Tags
351, 54l
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
