HOWTO: Tachometer Repair (WAS:Tach is all caddywhompus) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-03-2014, 09:11 PM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
If you are shopping to buy a Tachometer look for the newer style that has an IC chip and less parts. There is not a cover over the back, It comes out of the cluster just as shown.
This was taken out of an 1986 F150.
  #32
Old 08-04-2014, 10:21 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Interesting, I never seen that kinda of tach on these year of trucks. If possible what is the numbers that are on the IC chip? Its just out of focus to read it.
  #33
Old 08-05-2014, 02:06 PM
JimsRebel's Avatar
Quote:
LM1819 Air-Core Meter Driver
General Description Features
The LM1819 is a function generator driver for air-core
(moving-magnet) meter movements A Norton amplifier and
an NPN transistor are included on chip for signal condition-
ing as required Driver outputs are self-centering and devel-
op g 4 5V swing at 20 mA Better than 2% linearity is guar-
anteed over a full 305-degree operating range
Self-centering 20 mA outputs
12V operation
Norton amplifier
Function generator
Applications
Air-core meter driver
Tachometers
Ruggedized instruments
  #34
Old 01-05-2015, 02:31 PM
Ez2frag Ez2frag is offline
Ez2frag is starting off with a positive reputation.
Quote:
Originally Posted by Rogue_Wulff View Post
Yeppers. I solved Gary Lewis' tach reading too high in just a couple minutes time. His was a DS3 - DS2 conversion.
Near the DS2 box is a connector with 2 wires, 1 green, 1 black. The green wire goes to the coil, and the black wire goes to ground, but ONLY on a V8 truck. A factory 6 cyl truck will not have the black wire on the engine side of that plug.
As for the crud inside the tach causing erratic behaviour, these trucks are not the only ones that suffer from the issue. I need to disassemble the tach in my RX7 and clean it up. It works fine, till the temp drops to under 40F. I rarely remember about, since I rarely drive the car in temps cool enough to cause the tach to "wig out".......
Would you happen to know off hand where the ground wire from this plug attaches?
Thanks
  #35
Old 01-05-2015, 06:33 PM
JimsRebel's Avatar
Quote:
Thanks
The end of this ground wire, the point where it touches metal, is in side the Dist Cap.
This wire is also the sole point of ground for the entire in IGN system. So if the engine runs ... the ground wire is good.
Not really sure if this answers your question or not.
Jim
  #36
Old 01-05-2015, 07:10 PM
Thank you for your reply
  #37
Old 01-10-2015, 08:37 PM
Did this to my tach last weekend - worked great - now reads like it should and doesn't change readings at will. Note instead of the the q-tips I used a very soft old worn out toothbrush and it seemed to work nicely. Thanks for this tip.
  #38
Old 01-09-2016, 07:34 PM
xlt351 xlt351 is offline
xlt351 is starting off with a positive reputation.
Instrument panel
Hey fellas,
I have an Australian 1983 f100xlt 351c. I will be taking the in instrument panel/gauges out again as my Tacho is not working,and will post a picture of the rear circuitry . Ive read that the 1980 models in the US have a green circuit on the back and from 1981 on it changed to red. Well maybe we just got old stock over here. They tell me that the ones over here were a Canadian build etc . So I will send yall a pic
Cheers
  #39
Old 09-20-2016, 02:34 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
I just wanted to revive this thread to assure members that this thread is worth its weight in gold. This past weekend, while at the 2016 OK-GTG, the tachometer in my 1986 F150 was taken out and cleaned as detailed on page #2 of this thread and it worked as described! Thanks to Gary Lewis for his "hands on" assistance!
The inside of mine was no where near as "bad" as the one shown in this thread, but the tachometer still was not performing properly and after the cleaning, it reads correctly, again.
The symptoms of my truck's tachometer was this: it read 50+% high. It was as though both the 6 cyl. and 8 cyl. circuits were both being activated? Anyway, after cleaning, the tachometer is working beautifully.
  #40
Old 09-20-2016, 05:44 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
David - You are welcome. It was fun. And productive, although I had my doubts. That's because your tach looked clean to me. Even the Q-Tip we used on it only had a little bit of yellow, but apparently it was just enough to cause problems.
I'm glad it is now working for you.
intermittent tach..please help! av8theskies Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 02-04-2016 10:42 PM
E4OD/Tach Problems 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 03-21-2015 03:07 PM
7.3 tach failure HELP PLEASE shane86 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-23-2015 02:36 PM
factory tach needle hanging up blasterf150 1997 - 2003 F150 2 12-19-2012 04:02 PM
tach only works sometimes ford-lover1995 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-03-2011 04:10 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1979, 1994, 49, 73, coil, duraspark, erratic, f150, ford, ii, intermittent, pickup, reading, straight, tach, tachometer, taurus, tfi, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
