Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-03-2008, 07:02 PM
LilDuke's Avatar
He rides the short bus.
LilDuke is starting off with a positive reputation.
Head removal question I6 vs IDI
I've done a few strong arm head swaps on various I6's I've owned. Reading around here all I see is how you need a cherry picker. Compared to the I6 is the 7.3 head heavier or lighter?
__________________
Dave
'93 Ranger XLT 4.0, 4x4, 179,000 and counting. (For Sale)
'92 F-150 XL I6, M5OD, 4x4, 186,000 and counting. (For Sale)
'90 F-250 XLT 7.3 IDI, E4OD, 181,000 and counting.
'95 Explorer XLT 4L, 4R55E, 4x4. 156,000
Hiding in my own little corner of the world!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-03-2008, 07:16 PM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
The IDI head is not that heavy maybe about 70 lbs but when I did mine I just lifted them on and off. I did both head gaskets in about 5 hours from start to finish. I also pulled the exhuast manifolds with the heads to make it faster.
  #3 (permalink)
Old 08-03-2008, 07:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
If the engine is in the frame, they are rather heavy to be lifting around in the awkward position you will be in.
May be a bit different for a 2 wheel drive, but I can't even get a decent grip on mine in a 4x4 standing outside the truck.
If the engine is out on an engine stand, there is no problem lifting them.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 08-04-2008, 02:29 PM
LilDuke's Avatar
Ok. I've already unbolted the exaust manifolds, as I'm trying to narrow down where my exaust leak is coming from. I was going to slide it in the shop, and use the overhead. But moving my truck around by myself is not a feat I want to do often. Thanks Guys
__________________
Dave
  #5 (permalink)
Old 08-04-2008, 03:15 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Actually they are about 95 pounds each. Saw that from shipping data.
This is not a head that you should try and manhandle into or out of position. You need a hoist of some sort ot you will not be able to control it. Its heavy enough to take fingers off it if gets away on you, so be careful.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #6 (permalink)
Old 08-04-2008, 05:32 PM
LilDuke's Avatar
The problem is, I can't afford to keep this truck in the shop, and I don't have a cherry picker that rolls on stones. I also am working alone, as my wife weighs as much as one of these heads do. I guess I'm gonna have to build a "big wheel" cherry picker of some sorts.
__________________
Dave
  #7 (permalink)
Old 08-04-2008, 06:09 PM
Quote:
Its called a Tree Branch and a Hoist!
  #8 (permalink)
Old 08-04-2008, 06:37 PM
Tripod time.
My hoist is a tow behind setting on 8" pneumatic rubber tires.
It will move on gravel with a head on it, but not with a motor.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #9 (permalink)
Old 08-04-2008, 07:40 PM
LilDuke's Avatar
I keep looking over in the "pile'. There sits a welder/gen set trailer. Over there's a bunch of tractor wheel/suitcase/block weights. And Hmm... Theres a cherry picker cut off a flat bed truck, and theres a hoist crane with cable from another truck... Now where's my welder?
__________________
Dave
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
