Rolling on a paint job
I was recently looking through a paint/body magazine and saw an interesting article about a new method of painting sheetmetal: rolling it. It cost the guys about $150 for the paint and prep supplies, and the end result looked like a spray-job. Has anyone else done anything like this?
I have seen this topic come up from time to time on various forums that I frequent. I don't personally know anyone who's tried it.
Here is a link to a thread on a Mopar forum where it is discussed:
moparts: paint job on a budget!?
Depends on what you have more of or what final result you are satisfied with. I know a guy who did this way back in the 60's without color sanding after using single stage enamel paint. Looked decent at 30' up close looked like heavy orange peel like the paint wasn't thinned enough when sprayed. This was before the days of modern paints and foam rollers.
One of the car magazines just did an article where they tested the method by painting a Falcon Ranchero white using good old Rustoleum paint from the hardware store. They said it required a lot of color sanding but the finished job was equal to an Earl Shieb job.
Truthfully IMHO you'd be better off doing the prep and masking job then take it to your local ES or Maaco one day paint place. They use reasonably good paint and the spray gun guys get a lot of practice laying it down, where they cut corners is in the prep/masking. No sanding or priming, just power wash with harsh chemical spray, quick mask, no attempt to get under rubber stripping, emblems just get a top surface coat of liquid mask, etc.
Many of the auto paint manufacturers now recommend rolling as an application method for their high build primers before final blocking. SW even has a primer with 2 different catalysts, one for spray application and one for squeegie application.
Here's a link to the Hot Rod mag article:
'62 Falcon rolled paint job
And, a very nice job on a Corvair:
Corvair Cheapie Paint Job
And, a pic of the shine on a VW painted like that:
If you have more time than money, and beer than brains, it's the way to go! I think it would give a very period-correct finish to a truck. Not for me, I'm not THAT cheap any more, but I have done a few cars this way, when I WAS cheap...
R
R
I had a friend in school and his brother painted his car with a sponge!
Now his brother my friend probably didnt know a good paint job from a bad one but he said it didnt look to bad.
Now figure in it was probably a $200 car and these guys were teenagers.
I think most people will look at a car from 20 feet and if it sshinning its a good paint job.
