Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Alternative Fuels, Hybrids and Mileage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-02-2008, 10:17 PM
18vtx00's Avatar
18vtx00 18vtx00 is offline
18vtx00 is starting off with a positive reputation.
Question HHO experience w/ a 6.0L F350 or a 5.0L explorer
I posted this in my diesel section w/ no reply's before finding this forum.
I have been experimenting w/ making my own HHO generators this week and would like to know if there is any knowledge out there about using these on my 6.0L..
Any faults or things you may do differently to save me time,money and aggravation is greatly appreciated. thanks
__________________
FORD MASTER DIESEL TECH
ASE MASTER, L1
HEAVY TRUCK-DIESEL, ELECTRONICS
'03 F350, CC, 8', 6.0L, LARIAT-SPARTAN SCT, 5" SILVERLINE COOL DUALS
'96 EXPLORER, 4DR, 5.0L, XLT
'05 SKI-DOO REV ADRENELINE
'86 FORD 555 LOADER/BACKHOE
'03 VTX1800C
  #2 (permalink)
Old 08-05-2008, 05:07 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Yeah, don't waste your time.
It cannot work. Why? The Laws of Thermodynamics haven't' been repealed yet...
Same junk was around in the 70's.
The only way it can "work" (note the emphasis) is to screw with either your MAF or your upstream O2 sensors to force the mixture far leaner than the engine was designed for.
Your stated experience as a mechanic should be able to provide the answer to the following question:
"What happens to an ICE (whether gas or diesel) from running lean for too long?"
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 08-05-2008, 05:51 PM
18vtx00's Avatar
Really, seems like a lot of guys are getting good results after may attempts.I understand the fooling of the PCM is essential and is not that hard to do, I just wanted some input.. thanks
__________________
ASE MASTER, L1
'03 VTX1800C
  #4 (permalink)
Old 08-05-2008, 06:57 PM
I see you studiously avoided answering the question posed that would have exposed the flaw in your plan or in the reported "success" of others
We're still waiting....
__________________
  #5 (permalink)
Old 08-05-2008, 09:08 PM
18vtx00's Avatar
I am just looking for info and experience, that's all. Not sure I avoided anything.
__________________
ASE MASTER, L1
'03 VTX1800C
  #6 (permalink)
Old 08-05-2008, 11:43 PM
Quote:
The question is really simple and is above.
Still no answer? Hmmmm......
__________________
  #7 (permalink)
Old 08-06-2008, 12:11 AM
18vtx00's Avatar
It appears not too many FTE guys have tried anything on their own. Kinda surprised since most diesel guys try anything to get .5MPG or MPH.
I answer a lot of questions in my diesel forums and help guys out all the time, first time over hear and trying something new. Making HHO is a new experience.
__________________
ASE MASTER, L1
'03 VTX1800C
  #8 (permalink)
Old 08-06-2008, 09:51 AM
You still haven't answered the question:
__________________
  #9 (permalink)
Old 08-06-2008, 11:30 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
While this whole HHO, Brown's gas, water4gas, or whatever you want to call it is a scam and cant work, diesel engines run very lean most of the time, one of the many reasons they are more efficient. So, what is the problem with running lean for too long?
Unlike a spark ignition engine with a throttle, diesels always take in a full air charge with each intake stroke and vary the power output by regulating fuel flow. The latest direct injection gasoline engines, on some VW/Audi and Lexus, and was used on some large aircraft engines in the 1950's also allows for super lean mixtures. "Leaner is hotter" is a myth borne of 1960's attempts at crude emission controls with fixed jet carburators, going from way rich to slightly rich, which is hottest. Airlines and the military found that leaner is cooler, and cleaner, decades ago.
Jim
  #10 (permalink)
Old 08-06-2008, 02:17 PM
18vtx00's Avatar
Jim
I asked several kit makers this same question, will it run away since you have almost no vacuum in a modern diesel due to the lack of a throttle plate, and they insist it will work. Also how would you possibly cut down on fuel? They insist it works just by installing HHO in the air intake tube.
For these reasons I am not working this into my diesel, just seeking info from others.,I will make a kit for my 5.0L explorer as a test vehicle.. thanks for the info.
__________________
ASE MASTER, L1
'03 VTX1800C
  #11 (permalink)
Old 08-07-2008, 12:21 AM
Hathor's Avatar
Hathor Hathor is offline
Hathor is starting off with a positive reputation.
Post
Yes there is a company that makes a HHO generator for trucks 6.0 and 8.0.
I really dont want to give this company business by giving you a link.
this system contains water filters of which gives pure hydrogen gas.
The other hho generators make gas but it has a lot of moisture in it
  #12 (permalink)
Old 08-07-2008, 12:23 AM
Hathor's Avatar
OK FINE EVERBODY GO HERE AND AVOID THE QUESTION
MagDrive Fuel From H2O - HHO Generators
  #13 (permalink)
Old 08-07-2008, 08:34 AM
18vtx00's Avatar
Thanks for the info, why would you not want to send a link? Have you tried any of these?
__________________
ASE MASTER, L1
'03 VTX1800C
  #14 (permalink)
Old 09-05-2008, 06:34 PM
zpexploder zpexploder is offline
zpexploder is starting off with a positive reputation.
Talking HHO & My 5.0 Explorer!
I use HHO and a MAF sensor enhancer on my '96 5.0 Explorer. Works great, could not be happier. Hooking up a MAP/MAF sensor enhancer is too easy and works even better. My increase is from 18 mpg to 24 mpg. No joke!
Not huge but pretty good for AWD V8. I actually build MAP/MAF sensor enhancers now. Check em out if you need one. ************.com
  #15 (permalink)
Old 09-05-2008, 07:52 PM
18vtx00's Avatar
I would be happy w/ the 18MPG you claim as stock!! Got any pics of how you attached you kit? Thanks
__________________
ASE MASTER, L1
'03 VTX1800C
Tags
1997 , 50 , 97 , browns , enhancer , explore , explorer , f150 , ford , gas , hho , hotter , installation , lean , maf , map , myth , o2 , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
