1995 Ford F350 Transmission Problems - Ford Truck Enthusiasts Forums
Old 08-02-2008, 04:47 PM
pappi pappi is offline
pappi is starting off with a positive reputation.
I have a 95 F350. It has the 460 engine with 4OD transmission. It has been shifting very hard from 2nd to 3rd. The rpm's will go up to 4500 before it will shift. All other shifting is normal and smooth. I changed our the transmission filter and fluids this morning, The shifting is not as pronounced as before but is still there. This transmission is only had 2000 miles on it. The transmission pan, and small amounts of metal at the magnet. Nothing I would be to concerned about. Anything thing else that anyone can think of? Oh by the way the truck has a 12inch lift. Maybe that has soemthing to do with it, not sure.
Old 08-03-2008, 02:04 AM
gweeds's Avatar
gweeds gweeds is offline
gweeds is gaining momentum as a positive member of FTE.
Do you have huge tires and stock gears?
Old 08-03-2008, 11:56 AM
I have 36-16.5-15. I believe it has stock gears.
Old 08-03-2008, 12:33 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
did you drain the convertor?
Old 08-03-2008, 02:07 PM
No i didnt do that. I will give that a shot.
Old 08-06-2008, 08:37 PM
I am wondering. Since the truck has a 12 inch lift. I have a Dana Rear end. If the main pinion is not getting enough oil. I have heard that if that is the case if would also cause the truck to shift hard from 2nd to 3rd, anyone else heard this. One more thing Were is the speed sensor located. I want to make sure there is no metal on it. Since if there is is, this also might cause the transmission to shift hard.
Old 08-06-2008, 09:24 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
Do a full trans flush by disconnecting the line at the cooler. Get 4 gallons of fluid and 10' of clear tubing and cut in half. Connect to the lines and put the other end into a large plastic pan. Start truck and let run for 30 seconds and shut off. Estimate amount pumped into the pan and fill trans with that amount. Repeat until fluid is red like new. Piece of cake and should take about a half hour.
automatic transmission shifting problems Richard.Parker 1997 - 2003 F150 10 12-19-2014 07:50 PM
T98 gear shift knob 49fordv8f4 1957 - 1960 F100 & Larger F-Series Trucks 2 10-14-2014 08:43 AM
weird transmission thing fishernut 1999 to 2016 Super Duty 3 06-06-2014 05:42 PM
96 F350 transmission problem E40D 66f100prostreet 1987 - 1996 F150 & Larger F-Series Trucks 4 10-29-2009 12:03 PM
E4OD Shifted Hard scottw1 Clutch, Transmission, Differential, Axle & Transfer Case 2 01-16-2009 04:17 AM
Tags
1995, 1996, 1997, 40d, 95, diesel, f350, ford, issues, pickup, problems, shifting, transmission, transmition, truck, whine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
