Removing door sill? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Removing door sill?
Old 08-02-2008, 12:54 PM
Eric H's Avatar
Eric H Eric H is offline
Eric H has a good reputation on FTE.Eric H has a good reputation on FTE.
Removing door sill?
Does anyone know if there is room under the door sills for an 8 gauge cable? In my last couple vehicles I was able to make it fit. Also, do the door sills just pry up? I'd hate to break any plastic tabs, etc.
Thanks!
Old 08-02-2008, 05:22 PM
RIDE RED RIDE RED is offline
RIDE RED is starting off with a positive reputation.
yes there is plenty of room for the cable.Just lift the edge of the sill plate & you can see the clips.lift straight up.I use a flat blade screw driver to pop the clips up.
Old 08-02-2008, 09:46 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
4 guage will fit fine.
61-64 Sill / Scuff Plates FoMoCoPower WTB - Parts & other 4 04-22-2015 11:03 PM
64 door sill plates adam68 WTB - Parts & other 0 11-19-2014 09:15 AM
Need to replace my rocker panel (door sill) teamlx88 1997-2006 Expedition & Navigator 4 08-21-2013 01:57 PM
Bed cross sills dasaroth 1987 - 1996 F150 & Larger F-Series Trucks 1 07-28-2013 10:26 PM
1984 Ford Weatherstripping Stingray42 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-10-2003 02:47 PM
Tags
2000, 2008, door, f150, f250, f350, ford, plastic, plate, rear, remove, removing, sill, sills, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
