OIl Filters, Wix 1734? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-01-2008, 04:49 PM
03F2507.3 03F2507.3 is offline
03F2507.3 is starting off with a positive reputation.
I want to get a high quality oil filter to go with my new Schaeffers synthetic oil. I have read the past posts about oil filters and have seen lots of opinions but cant seem to find any tested proof of the better filters. Im not asking the age old question of which is best...just wondering if the Wix 1734 at $24 is that much better than the Motorcraft 1995 at $10??? Or is there a better option?
This question is assuming you have no bypass filtration and ~150k on the motor running synthetic oil.
Old 08-01-2008, 06:01 PM
DISLFVR's Avatar
DISLFVR DISLFVR is offline
Locomotive breath
DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.
Both are good, I've used both. If you buy at Fleet Filter you can get them for less, the wix 1734. I used the motercraft 1995 from Wally world last time 'cause I ran out of the others.
Old 08-01-2008, 06:13 PM
Quote:
fleetfilter has the 1734XE and the 1734. XE has 10 micron nominal rating with the same flow as the standard 1734 which is only 19 micron nominal. But the burst pressure is lower on the XE. Is 200 psi burst pressure too low? Im sure its not. Has anyone used the XE version?
Old 08-01-2008, 06:37 PM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
Wink
I have recently found the Purolator "PURE ONE" line of filters, the OIL is # PL44872 for our 7.3s they say they are 99.9% efficient, about $16.00 at the chain stores that sell Purolator products.
I just changed my oil with Shell Rotella Synthetic and this filter, I'm planning on 10k miles before I change it again, I will send in a sample at 5k miles.
Old 08-01-2008, 06:43 PM
JMac444 JMac444 is offline
JMac444 is starting off with a positive reputation.
It is a very good oil filter and have used it many years on the 7.3L psds with 0 problems but for 14 dollar difference buy 2 and a half motorcraft ones because there just as good.
Old 08-01-2008, 06:57 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I just bought a Motorcraft filter at Wally World for under $9.47. When I go back by that store next week I may buy 4-6 and just shelve them because for that price they can't be beat.
Old 08-01-2008, 10:23 PM
I want to extend my oil change intervals to 10k or more if I can, without a bypass filter. I think the pure one or the Wix XE should work well. I am going to try and find flow rates on the pure one.
Wix filters and green coolant Super Duty Service 6.0L Power Stroke Diesel 25 01-30-2015 08:31 PM
Oil filter fit question Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 12-28-2014 04:35 AM
New DieseltechRon video, bulletproof EGR/Oil cooler Bullitt390 6.0L Power Stroke Diesel 24 12-18-2014 09:06 PM
Motorcraft vs. WIX Oil Filter amorican88 2004 - 2008 F150 10 03-11-2014 03:31 PM
6637 on sale F350-6 1999 - 2003 7.3L Power Stroke Diesel 42 03-22-2008 10:26 AM
Tags
1734, 1734xe, 73, diesel, filter, ford, micron, nominal, oil, oill, pl44872, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
