110v compressor motor wiring
I’m replacing a motor on my small, approx. 10 gal., compressor w/110v motor. The on/off pressure switch is wired though the motor by the neutral. I was always taught to NEVER wire house switching through/by the neutral. Is this Okay to switch the neutral. Don’t have the NEC handy. Thanks for the help.
Switching a neutral is incredibly dangerous.
I'd wire it correctly regardless of how it was shipped from the factory (which is probably wrong).
NEC doesn't concern itself with the wiring of a device like this. UL (for US) (or the Canadian equivalent) would be the agency that would have any oversight.
Steve
Steve
Worked on a water heater in mexico yeasrs ago and first thing I did was open the circuit breaker. Then went to work disconnecting the wiring and just for grins I thought I would test it with my meter. Glad I did because as it turns out the breaker was switching the neutral. That could have been my last job!
on
1 Post
well if I read you right, the compressor mounted shutoff switch was wired this way, the swtich that shuts off the motor at a certain pressure and unloads the output line, and then turns it back on on a pressure drop?
the reason being, if the compressor is grounded (as it should be) or the piping (if installed) then if there is a switch fault or moisture/shavings in the line, you dont get an internal short (plus if the compressor is truly 110v and is plugged in behind a 20-pass20 GFI, it will trip on moderately humid days)
Last edited by Ranger88Den; 09-04-2008 at 02:42 PM. Reason: additional info omitted.
Necromancer
05-08-2014 12:22 PM
