Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 08-03-2008, 07:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Mine do.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 08-03-2008, 07:20 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Dave Sponaugle View Post
Mine do.
Not sure what you are showing in that picture, but if you are refering to the peanut shaped dish in the top of the piston, that isn't a valve relief, its the exit of the prechamber in the head.
I'll go and take some pics of the dimentions of the head, valves, and pistons so you can see what I'm talking about.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #18 (permalink)
Old 08-03-2008, 07:38 PM
Not even the picture I thought I posted.
Now to find the right one.
I really need to organize my stuff better.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #19 (permalink)
Old 08-03-2008, 07:50 PM
AREA 51 is starting off with a positive reputation.
yup your right, not even close to being valve relief.
  #20 (permalink)
Old 08-03-2008, 08:54 PM
David85's Avatar
OK, this is the 6.9 piston:
The valves in the head:
And an example of a diesel piston that does have valve reliefs: (mitsubishi 2.3 turbo)
You can see that the smaller piston had a larger prechamber dish in the piston than the 6.9. I'm not sure how they could get away with this, but it might have something to do with the bosch VE pump that was used on those engines. Who knows, but but both engines seem to be capable of smoke free operation without any emission controls (with a turbo).
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
