Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-01-2008, 12:15 AM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
Garage is empty, add now
CheaperJeeper is gaining momentum as a positive member of FTE.
SCORE! 3 storage tanks!
I got 3 free storage tanks today - just for going to pick them up!
They are the 275 gallon cube-style heavy plastic tanks inside a steel cage with a built in ABS pallet underneath and an ABS "deck" on top so they are stackable.
They came with a ball valve with a 1-1/2 inch cam-lock fitting at the bottom on one side and about a 7" screw-off cap in the center on top.
They should work well for storing & transporting veg oil. I'm also thinking of using one as a blending tank for mixing & dispensing my veg oil/RUG blend.
I want to try to install a male air hose nipple in the screw-on cap on top and see if I can get it to hold air pressure. If so I could then fit a hose to the cam-lock/valve assembly at the bottom and the blending tank and make it a dispensing station as well...
Anybody ever try to pressurize one of these?
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #2 (permalink)
Old 08-01-2008, 09:17 AM
SMOKEPLOE SMOKEPLOE is offline
SMOKEPLOE is starting off with a positive reputation.
i don't know about pressurizing them but i know about what happens when you put a pump on one and don't open the top for air vent. They fold up into a small ball. You might want to get an aro pump and use that for diispensing.
The vendor that we get the product from really likes when that happens. you might not want to go over 30psi air pressure they are not design for that. also they are only rated for 140f temp.
smokeploe
  #3 (permalink)
Old 08-01-2008, 04:41 PM
Thanks for the tips smokeploe. I don't expect I'll need to go more than 10 PSI pressure - maybe 20 PSI tops.
With the large surface area above the liquid being under perssure, and the relatively small outlet at the bottom, I expect that even low air pressures will produce plenty of pressure and flow - kind of like an air over hydraulic cylinder.
I'm not familar with the "aro" pump - is that an aero (air operated) pump?
__________________
  #4 (permalink)
Old 08-03-2008, 08:29 AM
yes it is sorry for the spelling error, a mech had to be a real pain in the but at that time.
we use a lot of those tank at work and they do fold up real easy and the vent plug on top sticks and get stuff in it an plugs up fast. we get olive oil and cannola oil in them--food production plant.
We tried using the pump from the drain valve and could not get it fast enough and collasped the hose 2" so we just open the top and insert the hose in the top of the tank. We lose about 3 gallons because we cannot get the last it out of the tank. The people that mix the product found out that there is some solids in the bottom of the tank so no lost oil really.
Good luck with the tanks.
smokeploe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
