Help Identifying 94.5 and 94 model 7.3
07-31-2008, 09:22 PM
Im looking to buy a 94 F350 with a 7.3 Diesel. My question is how do I know if this truck is a 94 or 94.5 and what is the big difference? Thanks in Advance?
07-31-2008, 09:54 PM
94=idi mechanic injection 94.5=powerstoke di electro & oil injectors
kurt
07-31-2008, 09:56 PM
easy to tell, injectors on outside of heads on the older ones.
07-31-2008, 10:16 PM
Take a look at the VIN. If the eighth digit is a "K" it's a 94 IDI, if it's an "F" it's a 94.5 with a PSD.
07-31-2008, 10:37 PM
on
metal fuel lines running allover the top of the motor means its an idi
07-31-2008, 11:06 PM
And if it's an auto it's an IDI. 1st year Powerstrokes only had the ZF5.
07-31-2008, 11:13 PM
The drivers side valve cover will have the info you need. If it says T44E its a powerstroke and if it says A185 then its a IDI.
08-01-2008, 06:10 AM
Quote:
Originally Posted by
ford390gashog
The emission label on a Powerstroke is on the right valve cover and lists the model as A215, T444E is the IH name and isn't used on a PSD
08-01-2008, 10:03 AM
hoe bout the label on the truck " electronic direct injection" he says its on the tailgate and vavle cover?
dougbrown
58
03-15-2021 08:05 AM
OBS Mule
01-15-2017 09:37 AM
Kyle_94obs
08-17-2016 09:52 AM
Meydawg51
16
10-12-2015 09:01 PM
Pete in Maine
05-27-2008 05:08 PM
