A/C advice pleas
A/C advice pleas
My PSD A/C is fine but I have a daily driver I need help with. The car is a 1999 Ford Escort ZX2 Sport with the 4 cylinder. The A/C does not work. Tried adding R134A, no luck. My mechanic says it is the compressor. If I choose to change this myself, what all do I need to consider?
Thanks
Thanks
First thing is to get the service manual and peruse it to see if you have the proper equipment and are up to the new challenge.
I'd also get a second opinion. You never know, that mechanic might have a boat payment due and he selected you to make it for him even though all the car might need is a simple or inexpensive repair.
You can get that help here if you have the capability to follow directions and use some basic diagnostic test equipment (gauge set, multi-meter, etc).
Steve
Steve
on
First
Don't go throwing parts at it.
Sure if you replace enough stuff it will get fixed.
Have the pressures checked.
That will give you a starting point.
Don't go adding refrigerant without knowing how much is in the system to start with.
You could overcharge it and do more damage.
It could be something as simple as a switch or clutch gap that is too wide.
I semi-frequently go over with topic with people/customers that get the Firestone/Pepboy or other $12 an hour expert that declares the whole system shot. In modern car A/C systems the compressor rarely goes bad, though when it gets replaced the problem gets solved.
Why?
The new ones come with a new $50 clutch. Run the vehicle and briefly jumper the clutch with fuses leads to see if it clicks and engages.
Why?
Rick E-350 V-10
08-17-2011 03:39 PM
