I have a 99 F150 with power windows. The driver side window won't roll up. I removed the door panel and can't figure out a way to get to the motor. Has anyone replaced one of these motors? Do I need to replace this motor?
Generally to remove a power window motor you need to drill three holes in the door. The location for drilling these holes is marked with three indentations. You drill the holes and insert a socket to remove the screws.
