White residue over degas bottle?
Before you run to the dealer, clean the area as best you can, drive normally don't change anything, check the area at the end of each day. If you find the residue think about what you did that day while driving that could have caused the puking. IF you can replicate the event it helps the tech in the long run, at this point they just start pulling the truck apart to "fix" symptoms and not the actual problem.
Being that you run a lift as well make sure the coolant level is at/or below the "MIN" mark on the bottle. Since you lifted the truck the level will drop but is still the correct amount for a stock truck. I overfilled mine and puked it all out, after dropping it to the "MIN" line all is good with no issues.
Well the truck is at the dealer already but if I had to guess when it happened, I'm going to say on a trip to Lake Powell in June towing the 5th wheel.
It was hot out and it's nothing easy towing that much weight up and down these grades out here. We go from 1000 ft of elevation to over 7000 ft in just a little over an hour! I had the pedal to the ground, the truck was screaming, and the fan was running at full throttle. It definitely is not the first I do it..
Service manager told me it could be that it's seeping out of the degas bottle seals and mentioned the white was a good sign, that so far at least, it's not mixed with oil.
But you are right, I want to know the cause of this. Why it puked to begin with?
so King, you got an EGT gauge?
"seeping", yea that's it
svc mgr> "the white is a good sign" -yea, for a repair!
It's obvious that if you expect that kind of service out of your 6.0 you should demand ARP headstuds when they replace the gaskets.
The reason why it did what it did is because you got high EGT's and the coolant was boiling in the EGR cooler and most likely compromised a breach in the headgasket.
Checking for hydrocarbons in the coolant will tell you more info on the gaskets.
based on your demand from your engine, I would highly recommend gauges.
The 7.3 would have delivered the goods you demanded but I still feel that once you figure out how to care for the 6.0 and know its limits you have a much better purchase. SO while you may or may not need head gaskets, do yourself a favor and protect it by knowing your EGT's . The 6.0 will get much hotter than it's predecessor under similar loads due to several factors.
So, don't worry too much about it all, you just now know it's limitations. Ford will take care of you on this as I'm sure it's still under factory warranty.
Under extended warranty? Yes.
Either case, regardless of damage, correct, Ford will take care of it but it is important to me, similarly to as what you're staying, to prevent this from occuring again.
Bummer.
You'd think these engines would sustain the word load their expected to make.
