Headlights won't come on
My instinct say it's either the Dimmer switch (cheapest & quick change) or the headlight switch.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[/font]
Do you have a relay for your lights? Mine would go out all the time but on my car the harnest connector thing to the colum melted for some reason and now my brights are on when the lights shouldn't be on unless the right turn signal is on strange. I would look at those, especialy if you installed a cd player or something, lights are good grounds till you turn them on
I had the same problem with my '96 Explorer The culprit was the multi-purpose switch on the steering column. Boy - it would have been so much easier if I had known the multi purpose switch could also wipe out the headlights. Replacing the headlights switch was a bear and it proved not to be necessary!
Good luck
Tony
Good luck
Tony
