HELP!! Diff pin won't come out! - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 07-29-2008, 07:34 PM
Fordpup's Avatar
Fordpup Fordpup is offline
Fordpup is starting off with a positive reputation.
Exclamation HELP!! Diff pin won't come out!
Hey guys,
I am working on my 86 B2, 4X4, needing to change the rear axle seals,7.5..
The diff pin lockbolt came right out, whole also, but the diff pin just won't come out. It seems to me that it is hanging up in the one spider gear. The diff pin itself will move about 1/8" and thats all.
Any help will be greatly appreciated.
Old 07-29-2008, 08:18 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Sounds like it may have spun dry or just failed and welded itself to the pin, hard to say from here! lol
Did you try heating the spider gear first, then knocking the pin out? Heating it may expand it enough to get it off.
It should slide right out of the spiders just a smooth as can be, you may end up having to cut it out if its really that stuck.
Old 07-29-2008, 08:26 PM
Fordpup's Avatar
I will definitely try the heat tomorrow if its not raining. I ran out of enough light to keep working on it tonight. The heat treatment is starting to sound like the way to go. I hope it works. The funny thing is, this was supposed to be my SPRING project... lol.
I will keep you informed on my progress. Many thanks.
Old 07-30-2008, 04:24 AM
Help I M Stuck Help I M Stuck is offline
Help I M Stuck is starting off with a positive reputation.
that pin will not come all the way out..it will pop out enough to allow you to push the axles in to get the C-clips off.
Just make sure you remove the 8mm retaining bolt that keep it in place first.
Old 07-30-2008, 07:22 AM
The pin will come all the way out, it has to clear the space between the spiders to allow the axle shafts to push in.
Old 07-30-2008, 12:06 PM
mine came out enough to give me clearence to push the axles in to get the C-clips off.
Old 08-04-2008, 10:49 PM
Fordpup's Avatar
Hey guys.... success!!! Got the axles out and the seals changed. Help I M Stuck was right about enough clearance. There is a channel in the diff pin that allows the axles to be pushed in enough to remove the c-clips.
Worked for me, and I didn't have to beat the gears all up.
Thanks Help I M Stuck!
Old 08-07-2008, 07:33 PM
Glad you figured it out, I was under the impression you couldn't move the pin at all to start with.
Been a while, I took the diff out of a 86 and put it in a 88 some time ago now. I striped another one to scrap the body. I do remember completely removing the pin. Just not if it was before or after removing the axles. I don't know why but for some reason "before" comes to mind but it may not have been till after I had em out.
Anyway hope I didn't add any confusion, posting that it would come all the way out first.
Old 08-08-2008, 11:01 PM
Fordpup's Avatar
No prob, danr1... On a side note, I just changed the rear axle seals in my 1989 F150 2 days ago. That diff pin slid right out. Lucky for me I guess. The lockbolt came out very easy as well. Hardly had a scratch on it. I did replace it with new though.
Funny how things work out. Thanks for all the input guys!
Sterling 10.25 cross pin removal redbayredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 03-14-2016 01:36 PM
8.8 diff cross pin retaining bolt broke. Can't remove pin UNTAMND 1987 - 1996 F150 & Larger F-Series Trucks 7 02-13-2016 10:51 AM
NP435 transmissions Dave 64 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-04-2014 10:14 AM
Parking lights won't turn off. Tried everything!! p51man Electrical Systems/Wiring 3 09-26-2013 07:49 PM
Caliper slide pins, dumb question garydmundy 1999 - 2003 7.3L Power Stroke Diesel 4 06-22-2013 07:13 PM
Tags
axle, dif, diff, differential, gear, gm, main, pin, rear, spider, stuck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
