Door panels
on
I got my left and right mixed up! But there is a solution! you can remove the panel that the window switches are on and switch it to the good panel. The only problem is if that panel is the part that is broken. I have done it with good results.
They use some staked over plastic studs so I just took a drill bit and drilled the staked part off and then glued the panel back on.
Branded
22
04-03-2014 07:44 PM
likeagoodbook
02-11-2013 07:09 PM
400inatruck
07-11-2012 01:28 AM
arrowheadfred
11-08-2010 10:23 PM
