AC Compressor Clutch failure questions
I have a AC compressor clutch that has let go. the serpentine belt pulley is wobbling like crazy around body of the clutch making strange noises and the clutch is trying to engage but can very well. How does the AC clutch come off. Do I need to drop the compressor for access. Are special tools needed for removal? Thanks for the replies
Haven't worked on an a/c in years, but it sounds like the bearing in the pulley is toast, which most likely damaged the clutch. The compressor assembly is comprised of the compressor itself(pumps the refrigerant), a coil(pulls the clutch and locks it against the pulley like a magnet when powered up), the clutch is splined onto the compressor shaft and turns the compressor shaft as fast as the pulley turns.
Most clutches have a nut in the middle that needs removing, then you need to have a puller, which a free loaner maybe available at Autozone. The pulley is "usually" held on by way of a big snap ring or some of the newer models are pressed on I think.
Rockauto has a hub for $47, pulleys range from $38-$58, bearing for $23, or the whole assembly with the coil for $110.
Blockfort
08-30-2016 12:07 AM
tjc transport
03-24-2016 04:15 PM
