Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Virginia Chapter Join Chapter, Leader: archtaan
  #1 (permalink)
Old 07-29-2008, 11:58 AM
Sawduster's Avatar
Sawduster Sawduster is offline
Garage is empty, add now
Sawduster is starting off with a positive reputation.
Va.Beach area trusted/competent Mechanic?
So, I might have a problem with the front bearing(s). I have a squeak that is continuous but goes away when brakes are applied or the road curves. One mechanic said it was brake pads and he could install quieter pads. (45k miles on current).
That said, I've been hearing bad things about Beach Ford's repair shop. Any suggestions or ideas??
Thanks.
__________________
'02 F350 7.3 Lariat CC LWB
Arizona Beige w/Black Accent.
Superchips tuner, AFE stage II, 4"stainless MBRP,
4" Superlift, Toyo M/T's-35x12.50R18 on 18x9 chrome MotoMetals-951.
'00 Expedition XLT, Blue, for the wife.(w/ a phone charger)
  #2 (permalink)
Old 09-07-2008, 11:21 PM
HAUS189 HAUS189 is offline
HAUS189 is starting off with a positive reputation.
Hey whats up
I would try to take it to an offroad shop. Try Twisted Diesel or ETA, after having the lift and stuff they would probably be a little better with those kinds of issues.
  #3 (permalink)
Old 09-08-2008, 06:45 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
1987 Ford F-250
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
I should stop in here more lol
Get some anti-squeal and DIY
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4
VIRGINIA CHAPTER
Virginia Chapter Website
  #4 (permalink)
Old 11-19-2008, 07:17 PM
SSG VA BEACH's Avatar
SSG VA BEACH SSG VA BEACH is offline
1999 Ford F-150
SSG VA BEACH is starting off with a positive reputation.
I have been dealing with Ross Anderton at the Shore Drive Shell.
They seem ok so far but you know there hourly rate is high (not as much as beach ford probably, I don't care for them much either)
The shell lets you track your work and maintenance on there web site which is nice.
Eric
99 F150
  #5 (permalink)
Old 12-14-2008, 07:58 PM
MissIndependent's Avatar
MissIndependent MissIndependent is offline
MissIndependent is gaining momentum as a positive member of FTE.MissIndependent is gaining momentum as a positive member of FTE.
stuff i can't do myself, i always take mine to cavalier garage at the oceanfront. jody dudley is the owner...if you go there, make sure you tell him i sent you
__________________
"she's not crazy, just a little misunderstood"
1996 F250 XLT 7.3L PSD SC/LB 4x4, auto, 4.10s, 4" suspension lift on 37" Goodyear Wrangler MTs, 6637 air filter, 208k+ mi and counting
Plotting: stacks, gauges, tw chip, cat/muffler delete, and more that won't fit
  #6 (permalink)
Old 12-14-2008, 08:56 PM
Cavalier Garage???
Is that the same as cavalier ford or is this a actual garage??? I have had great luck with twisted diesel, actually i might have a oil leak from the little drain hole under the trans area. Anybody have any idea what it might be??
  #7 (permalink)
Old 12-14-2008, 10:34 PM
1999 Ford F-150
Oil or trans fluid ? not sure what set up is under an F350 as for any known problem area's. Maybe someone with more knowledge will help you out.
Eric
99 F150
  #8 (permalink)
Old 12-15-2008, 06:49 PM
Quote:
no, it's a really small garage behind the cavalier hotel. definitely not a dealer
__________________
  #9 (permalink)
Old 12-15-2008, 07:09 PM
1999 Ford F-150
Near the golf course ?
Eric
99 F150
  #10 (permalink)
Old 12-15-2008, 07:25 PM
yep, on holly road. jody doesn't mind me being back in the garage while they work, so it's a good way for me to learn...cuz i have lots to learn still
__________________
Tags
beach, cavalier, dudley, ford, garage, jody, mechanic, va, virginia
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
