1995 Ford F-350 7.3 Powerstroke headaches
No, no parts left over, for a change, lol. I replaced the o rings when I was putting the motor back together after the piston went in. For a while, it would crank, and run, then it would crank, run for about 10 to 20 minutes, and quit for a few hours, then it would do the crank, run 10 to 20 min, and quit. I had oil pressure, at one time after putting it back together, but I was messing around with it, and realized that the resovoir is empty, and won't stay full. Anyone know where I could get breakdown pics of this particular motor, so maybe I can identify something that was lost? Thanks.
If you had the gears in the LPOP apart ,,they only work one way...
No, I did not take the gears apart in the LPOP. When I took the motor out of the truck, I had it sitting on it's side for a couple months until I could get the parts to put it back together. After I put it back together, the truck started and ran for about 45 minutes, then quit. Then it would run for about 10 to 15 minutes, ( after being started on starting fluid ) then cut off, and would not restart for quite some time afterwards, even with starting fluid. I take it that there is no way to prime the LPOP?
A worn front cover can cause this also ,,,,,,
The LPOP supplies oil to the HPOP plus all the other engine internals ie. crankshaft, rods ect.
LPOP = 60 psi
HPOP = 3000 psi
LPOP = 60 psi
HPOP = 3000 psi ( really 3000? or 300? )
That HPOP seems like a lot, but then again, I guess it would be for the job it does, huh?
Wow, thanks for that information. Is there a way to check to see if it is the pickup tube or oil pump, w/o removing them? Just wondering, I would hate to have to remove the motor for the 3rd time, to replace the pick up tube. Thanks.
