Will a 6.0 Fuel Pump Work in the 7.3l?
And the downside is, it's a pain to crawl under there and get messy trying to change it. Welcome to FTE RDCampbell.
It looks like the 6.0 pump has 2 lines going in and 2 coming out (at least in the diagram). It looks like the're made to run a min. of 45 psi fuel pressure, which just happens to be the exact same min. fuel pressure for the 7.3.
Since the fuel pump is an on/off type of contraption, and excess fuel still returns to the tank, I don't see any reason this wouldn't work. It will probably require some slight modifications to the plumbing and electrical, and you'll have no way of knowing when the water separator down there needs draining. I'd carry the 7.3 pump and some hoses with me after the swap just in case you develop any issues.
If you do this, let us know how it works out.
6.0l Lift Pump? Racor Filter?
I have a Racor Marine filter and would like to do a lift pump and a pull pump.
Kinda like this:
Welcome to guzzle's Helper/Lift pump Web Page
Using the 6.0l pump as the lift pump, @ the tank (not inside).
The racor is a 2 micron filter. I have all of these items, just looking to see
how they would work together.
Thanks Bobby
Kinda like this:
Thanks Bobby
There is a truck locally that was t boned and I'm buying the fuel line, but if you want the pump which is still good let me know and i'll have him set it aside also. The 6.0 pump has 4 connections, and doesn't interchange w/o some modifications to your fuel system from what i have heard. You're in Fl though so it may be a bear to ship...
Ray Mathews
06-03-2021 06:40 AM
Affordable12
1999 to 2016 Super Duty
12-26-2016 06:54 PM
Powerstroke-7.3
13
12-29-2009 02:45 PM
