Clanking Sound
Clanking Sound
When i drive down the road i hear a clanking sound at about 1900 rpms but then it goes away, also it doesnt make the sound when i push the clutch or in nuetral. It sound as if it is coming from my transmission or transfer case. Any help is greatly appreciated.
1994 F-350 Diesel
1994 F-350 Diesel
Does the truck rattle alot when you turn the engine off? Or when you first start it? If so, it's the dual mass flywheel. If that's the case, I highly recommend Valair. www.valairinc dot com. Check them out, find the clutch set up you like. Call and talk to Dan Vallance and tell him Cody from Death Row Diesel sent you and he'll make the price even sweeter. His clutches and customer service are second to none. Good luck man.
