Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-28-2008, 12:38 PM
biz4two's Avatar
biz4two has a good reputation on FTE.biz4two has a good reputation on FTE.
Arrow '09 5.4L Triton HP/Torque numbers...Released
Just in case I missed the thread here...I figured I'd share this info for anyone who missed it too.
2009 F150 5.4L
Regular Unleaded:
HP = 310 hp
Torque = 365 ft/lbs
E85 Version
HP = 320 hp
Torque = 390 ft/lbs
biz
__________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-28-2008, 01:09 PM
FLYBOY07's Avatar
FLYBOY07 is starting off with a positive reputation.
Quote:
2009 F150 5.4L
Regular Unleaded:
HP = 310 hp
Torque = 365 ft/lbs
E85 Version
HP = 320 hp
Torque = 390 ft/lbs
biz
hmm that's a bit of a disappointment dont you think.. they could of done a bit better especially with everyone else pushing ATLEAST 330+ and getting the Same if not BETTER MPG. granted trucks ain't selling like they used to but still..come on
__________________
Ford F-350 CC- DRW -PSD- Centarus Conversion Package
  #3 (permalink)
Old 07-28-2008, 01:16 PM
tjthegreat is starting off with a positive reputation.
i could care less..im sure it will still outsell all its competitors
  #4 (permalink)
Old 07-28-2008, 01:27 PM
builtfordtough13's Avatar
builtfordtough13 is starting off with a positive reputation.
Those don't make sense to me, because isn't e85 usually less powerful than gas?
__________________
Jake
Mine: 1994 F-150 4x4 Supercab, 351, E4OD, Light Santa Fe Clearcoat/Medium Polomino Accent 157,000 miles
My Project: 1978 F-150 Reg Cab 4x2 302 C4 Brown
Mom's: 2001 Focus SE Sport, 2.0L Zetec Fort Knox Gold 136,000 miles
  #5 (permalink)
Old 07-28-2008, 01:30 PM
Fosters is starting off with a positive reputation.
where did you see this? just curious..
That is a bit of a dissapointment considering people can get more gains out of a CAI and tuner out of an 04-08...
Quote:
E85 is also much higher octane = able to run more timing = more complete burn = more power. works even better w/ forced induction setups...
__________________
2000 Excursion Limited 4x4 V10 - soon to not be stock anymore.
2004 F150 XLT screw 4x4 5.4 - 2.5 leveling kit, 34.5" BFGs - Gone
2004 mach1 mustang, holding the garage floor in place.
  #6 (permalink)
Old 07-28-2008, 02:11 PM
i heard e85 is corrosive.can some1 tell me if thats true
  #7 (permalink)
Old 07-28-2008, 02:35 PM
Power Kid is starting off with a positive reputation.
I call BS. Ethanol "higher" octane rating is not equivilant to gasoline. It will not prevent predetonation. This has been discussed a billion times by now but ethanol only has @ 2/3ds the nrg of gasoline, so how would a fuel with less nrg somehow produce more power? I can't recall the models but in the past when Ford has had two tiers of output ratings the Ethanol figures were the lower...
  #8 (permalink)
Old 07-28-2008, 02:39 PM
V8EXPLR is gaining momentum as a positive member of FTE.
Owning an FFV and using E85, I can actually feel a slight, very slight (seat of the pants) increase in performance when running E85. Also from what I've read, E85 can produce more power, it's all based on the compression rate of the motor. If a motor was built soley for E85, the compression rate being considerably higher than gasoline, then you'd get more power and better mpgs when running E85 than gasoline. The reason E85 is so bad on mpgs currently is due to the motors needing a lower compression ratio for gasoline, decreasing E85's efficiency.
__________________
Justin
2006 Ford F-150 SuperCrew XLT Chrome Edition
5.4L Flex-Fuel, 3.73LS, 18" Stock Rims, 18" BFG Rugged Trail T/A's, Trailer Tow Pkg
Sun/Moonroof, Fog Lamps, Ford Bedliner
Lund Headlight & Taillight Covers, Lund VentVisors
  #9 (permalink)
Old 07-28-2008, 02:43 PM
I see said the blind man.
So the new 5.4L would then have to able be able to variable adjust compresion based on actual belnd of ethanol in the fuel? So then if after a full tank of e85, if I put in 100% gasoline then it would detmine this and lower compresion as I drive? Or would it be all or nothing in that if it detects e85 I'm running higher, then if a retailer is not honest and actual mix is "e78" I don't get the benefit? Just some q that pop up in my head.
  #10 (permalink)
Old 07-28-2008, 02:44 PM
Quote:
Never seen Ford published figures showing lower ethanol firgures. Of course I've never seen Ford provide 2 different set of numbers on any motor, unless they were tuned differently for different applications (ie 4.6L F150 vs Stang).
__________________
Justin
  #11 (permalink)
Old 07-28-2008, 02:45 PM
My dealer was telling my it was a ranger or taurus a few years back. Can't recall. But ethanol was lower.
  #12 (permalink)
Old 07-28-2008, 02:46 PM
Must have been the 3.0L that I had in my '99 Ranger that was also in the Tauras. Never used E85 at the time or looked into it, but can't say for sure if this was true or not.
__________________
Justin
  #13 (permalink)
Old 07-28-2008, 03:03 PM
I'm not sure how they'd make a motor adjust compression, that's a lot more advanced than what they have in their FFV's currently. Currently from what I've read, there is just a sensor that determines how much alcohol is present and adjusts the air/fuel mixture and makes sure the system doesn't show it's running lean on E85.
__________________
Justin
  #14 (permalink)
Old 07-28-2008, 04:31 PM
REDFORDFX4 is starting off with a positive reputation.
2009 F150 5.4L
Regular Unleaded:
HP = 310 hp
Torque = 365 ft/lbs
E85 Version
HP = 320 hp
Torque = 390 ft/lbs
biz
And you got those #'s From Where exactly has it been from ford????
  #15 (permalink)
Old 07-28-2008, 04:53 PM
ffdemoss is starting off with a positive reputation.
Regular Unleaded:
HP = 310 hp
Torque = 365 ft/lbs
These figures showed up on the 2009 Expedition Order Guide. It could be different from the F150, but I doubt it. The E85 figures were not on the Expedition Order Guide.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
