Good service department near Lincoln NE? - Ford Truck Enthusiasts Forums
Nebraska Chapter Join Chapter, Leader: 97nukeford
Old 07-27-2008, 09:41 PM
Biggziff's Avatar
Biggziff Biggziff is offline
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
Any recommendations on a good dealer near Lincoln, NE? My V10 is sick and I need to be back in NY.
Old 07-28-2008, 08:50 AM
Redneck-Cowboy's Avatar
Redneck-Cowboy Redneck-Cowboy is offline
Redneck-Cowboy is gaining momentum as a positive member of FTE.
What happened? Drop a coil pack or something (missing)?
Old 07-28-2008, 12:22 PM
Biggziff's Avatar
started losing power..let it sit for 20 minutes and it ran fine again....Anderson Ford in Lincoln said it had a code for a fuel rail temp/pressure sensor so they replaced that..I'm not convinced this was it, but we'll find out soon...heading out again in 30 minutes...
Old 07-28-2008, 12:29 PM
Fuel rail temp/psi sensor? Hmmm, might have to look into that a bit, haven't run across that b4.
Old 07-30-2008, 03:38 PM
Biggziff's Avatar
Just made it home. 1800 miles give or take and no more problems. Whatever they did seems to have corrected the issue.
thanks again
Go Back   Ford Truck Enthusiasts Forums > >
Tags
anderson, diesel, ford, lincoln, nebraska, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
