Brake pedal close to the floor
If drum rear brakes(I can't remember whether they were disk by then or still drum)one or both adjusters rusted, frozen causing exssesive shoe clearance to drum, a thought or possible exsessive slack between pedal and master cyl. either in linkage to booster or booster to master. There is a rod from the booster to master cyl. piston that is adjustable, have to be carefull not to adjust too far out as will close off return hydrolic ports to cyl. caussing brake application and drag with the pedal released. When I adjusted this rod for a new cyl. repacement I would run the adjust out until when I held the cyl to booster with no pressure the rod against the piston would hold the cyl out away from the booster housing then I would run the adjust back to where the cyl just seated against the booster housing then back it in quarter turn more to assure min piston rod contact when released. I know there is an official way to set this up but at the time I found this faster and accurate.
I think he said adjust the rear brakes...unless you have done recent brake work ( i.e. -replacing the master cylinder or brake booster),that should fix your problem...
RangerRuss
01-27-2014 10:08 PM
hawncase
10-08-2012 06:29 PM
