How to bench test starter motor. - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 07-27-2008, 12:05 PM
fred_79f250 fred_79f250 is offline
fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.fred_79f250 has a great reputation on FTE.
Gentlemen,
I just took the starter motor off my 2000 Expy and I want to bench test it to confirm that it needs replacing.
The ground (black) cable was connected to one of the starter motor body mounting bolts, so I can use the body as ground.
There are three connection posts on the solenoid:
- one with a little wire that goes directly into the starter, and that I haven't touched.
- a small post that had a smaller black wire in a braided jacket to it
- a larger post that had the red (positive) cable to it.
When it was on the vehicle, turning the key would cause the solenoid to actuate, but the starter motor didn't turn. Now that it's off the vehicle, I can't even get the solenoid to actuate. So I figure I'm just not applying 12v to the correct posts.
Anyone?
Thanks.
Old 07-27-2008, 12:37 PM
Never mind - figured it out.
With ground to chassis:
- 12v directly to the post with th little wire going into the body should drive the motor
- 12v to the small post should actuate the solenoid
On mine, both functions are hit and miss. That is, sometimes they work, sometimes they don't. Even with what I believe are good connections. Like it's stuck. Looks like I was lucky and it failed in the driveway instead of in a parking lot a hundred miles from home.
Old 07-27-2008, 01:15 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Sounds like one of those starter-mounted solenoid type starters. Many parts stores have setups where they can bench-test it for you, but it looks like you already figured it out. Starters have so much torque that I'm a little weary of setting it on the bench in the garage and trying to run it.
Old 07-27-2008, 01:32 PM
Torque - ya, I recall that from the last one I pulled years & years ago - but not this one. I mean, when it does turn, it jus turns. No jolting torque, just a gently turning motor. Maybe that's part og the problem.
Old 07-28-2008, 12:22 AM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
i gently secure the starter in a vise to keep it in one place when i bench test one, had one get away from me a few to many times lol!
Old 07-28-2008, 10:58 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Since the gear is not engaged to anything but air, there is not much torque to worry about. Ive tested many starters on the garage floor. They just move a little bit. One important warning (no I did not do this myself), DO NOT TOUCH THE STARTER DIRECTLY TO THE BATTERY POSTS. Batteries give off hydrogen and oxygen when they are working and any spark can cause the battery to explode.
Jim
Old 07-28-2008, 02:37 PM
dono dono is offline
Gone but not forgotten.
dono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud ofdono has much to be proud of
I used to bench test mine with vice and jumper cables, but now I just take it to the local Auto Zone and they test it.
Old 07-29-2008, 09:16 AM
GlennFordx4's Avatar
GlennFordx4 GlennFordx4 is offline
GlennFordx4 is gaining momentum as a positive member of FTE.
I have had them wind up on the floor so now I use my big vice and a remote starter with my jump box to test them.
Old 08-07-2008, 01:22 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Its likely the solenoid on the starter itself that has failed. Permanent magnet starters are so incredibly more reliable than the old style starters they replaced. Usually the solenoid can be had for a fraction of the cost of a new starter, maybe $30-40 at most.
starter problems fordatic 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-23-2016 02:28 PM
Help! '84 F150 starter won't stop turning shadetree enthusiast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-18-2014 04:39 PM
Electrical starter problems Rich1953ard 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 04-28-2013 11:34 AM
Starter just spins....(one click) not just spins CD1993 1987 - 1996 F150 & Larger F-Series Trucks 8 08-27-2012 12:11 PM
How to bench test a starter motor zenmaster Electrical Systems/Wiring 9 05-24-2009 05:33 PM
Tags
1966, bench, cables, check, easy, ford, jumper, motor, solenoid, starter, test, torque, truck, trucks, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
