Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 01:13 PM
TheDuke's Avatar
TheDuke TheDuke is offline
TheDuke is starting off with a positive reputation.
Quote:
Originally Posted by FordTruckGirl77 View Post
Slip joint regreasing
Now the only thing is when you take the bands/clamps off the boot they dont go back on the same. We bought the tool at Kragen for $10 instead of buying the new boot which was almost $50. I guess you can use cable ties as well.
What kind of tool and for what? cable ties as in plastic zip ties? The picture in the link looked as if he used a metal hose clamp at least on one end.
__________________
04 F250 CC SWB 6.0 FX4 Lariat
BFG 305-65R18s on Stock 8" Rims
Engine Build Date 06/14/04
  #17 (permalink)
Old 07-03-2009, 01:46 PM
6686L 6686L is offline
6686L is starting off with a positive reputation.
this is interesting - apparently, more variations on EX drive-line components than I originally thought. My EX is an 05 LTD. 4wd. V-10. Has ONE drive-shaft - looks like pretty "conventional U joints and spline-shaft at the foward end" combination.
My neighbor has a 1 ton V-10 extended pick-up which, from the back of the rear door foward, appears identical to my EX in EVERY way EXCEPT that (because of the greater length, obviously) has a TWO piece drive shaft (again, the u joints and slip joint all appear to be identical to mine (no CV/"double carridans..").
Some of you guys are reporting seeing double carridans. Is that because you have diesels, with their MUCH greater raw power and torque ? Or was this just a "running production" change for all models ?
At roughly what mileage are you guys pulling the splines out for re-greasing?
  #18 (permalink)
Old 07-03-2009, 03:39 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
Mileage typically isn't the issue. Or rather, I haven't seen a mileage pattern. Some do it right from the lot other maybe at 15K or so. Still other don't have an issue until 50K while my current Excursion has never had the issue.
My 2000 did but was under warranty and they put in a whole new driveshaft. On that one the slip yoke was at the bottom by the diff. The new driveshaft has the slip yoke up top.
And have never seen an Excursion driveshaft with a CV joint and any end.
__________________
Ken
Cats; nasty creatures...
  #19 (permalink)
Old 07-03-2009, 08:59 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
I don't know why everybody is into chalking driveshafts. They are supposed to be balanced. I took hundreds apart when I R&Rd trannys years ago and never had a problem.
  #20 (permalink)
Old 07-04-2009, 09:50 AM
TheDuke's Avatar
I still can't figure out what kind of clamps to use...
__________________
  #21 (permalink)
Old 07-04-2009, 10:05 AM
gr8scott72 gr8scott72 is offline
gr8scott72 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Monsta View Post
Make sure you chalk the wheels!!!!!
Wheel chocks.
__________________
Scott
2000 Excursion XLT 4x4 V10 4.30, Powerslot slotted rotors w/ Hawk SuperDuty pads up front, Hawk SuperDuty pads on the rear stock rotors, Roadmaster Active Suspension, Optima Red Top Battery, backup camera, Tom Tom XL100 GPS
  #22 (permalink)
Old 07-04-2009, 03:14 PM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
Quote:
Originally Posted by gr8scott72 View Post
Wheel chocks.
Thanks Scott. I had a total brain fart above!
TheDuke, a common hose clamp will work just fine.
__________________
Ken
  #23 (permalink)
Old 07-04-2009, 10:03 PM
dave91gt dave91gt is offline
dave91gt is starting off with a positive reputation.
I have personally seen three variations of Excursion driveshafts.
1. Standard driveshaft with single U-Joints at either end and the slip yoke closest to transfer case- what mine has
2. CV driveshaft with slip yoke at pinion side. A friends 05 EB 4X4 had this from the factory
3. Standard driveshaft (same as #1) except with a rubber dampener at the pinion side made onto the driveshaft. This was on an 04 Limited 4X4
__________________
91 Mustang GT 5.0L 302, 5 speed, 4.56's, .616 solid roller, Pro Topline heads, etc. 8.09 in the 1/8th 3100lbs
03 Excursion V10 4.30's , V codes, 350 blocks, 305's, Monroe Reflex's, dents and vibes
09 Jeep Wrangler "X" Unlimited
  #24 (permalink)
Old 07-04-2009, 11:02 PM
EXv10's Avatar
I used to R&R stick and auto trans as a job and you would be surprised how many variations there are including closed drives. Chrysler had a joint that was like a u-joint with no caps that slid back and forth in a tube (hard to explain). Some had constant velocity joints and then there were the 2 piece shafts.
  #25 (permalink)
Old 07-05-2009, 12:06 AM
EXv10's Avatar
There is no need to remove that boot to grease the splines if I remember correctly????????
  #26 (permalink)
Old 07-05-2009, 02:28 PM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
No, but you have to undo one end. The clamps from the factory get destroyed upon removal.
__________________
Ken
Tags
2000 , drive , driveshaft , excursion , f350 , ford , grease , greasing , joint , pickup , rear , shaft , slip , spline , yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
